Genius
Smart Solutions - DIY
Remove +91 preceding any number and adding 0 ---- Part 2 (iOS)
after android this is part 2
So this is for iOS device
Get this
http://www.gamzabox.com/13
GeniusDailer
post-24516-0-82098100-1314771238_thumb.p
iTunes
http://itunes.apple....d417629273?mt=8
get it from below if you dont want to pay - use instllous to install them.
http://www.filedude....pXwZl4fc013b998
http://fileape.com/dl/jaUVQBb1xZ5GztgW
Video:
http://www.youtube.com/watch?v=d6rBLYacIro&feature=player_embedded
It has settings where you can Prefix 0 and avoid +
women,beauty,susan,coffey,susan,coffee,relax,red,girl-5fc5b48308f95b28e6e0b9ca34e241d5_h.jpg
Edited by Genius
plase create code for outgoing smses too,,, for Android! thanks!
^^ please brief what you want my friend
Taptalk on ™iPad 2
Taptalk on ™iPad 2
sir +91 fixer for android!
thanks
Shanu your answer in 2nd last para
Solutions - DIY#entry241580
Still not done
Genius bro please create a new rule for outgoing SMS with a prefix "0" instead of +91.. thanks
^^^ I haven't checked if they have integrated it in or not shall get back on this
Taptalk on ™iPad 2
Mr. Genius, tum jiyo hazaaron saal... :-P
Had the same problem on my Droid Incredible 2 running China Telecom ROM.
Worked like a charm, but only after clicking on the link from the phone. Scanning the bar code/QR code from monitor or creating manual didn't work.
Really awesome! A zillion thanks! :-D
There have been queries regarding this so here is the answer...
I have the solution for Android and iOS based device - have tried some thing with WebOS but nothing worked.
Android
Get Prefixer - free app from market
https://market.andro...tbelow.prefixer
post-24516-0-06841800-1314692377_thumb.p
get any brocode / QR code scanner from market install it.
go to menu >> add rule >> use barcode and point to following
post-24516-0-81888500-1314692572_thumb.p
the above QR code is for configuring prefix rule its done automatically
Or you can click this link on your android mobile
http://www.253below....59&LC=def&CC=no
you will see the rule in prefixer enable it
DONE you have configured it - next time when you will call +91 will be replaced with 0
this is only for outgoing calls - if someone else needs incoming too let me know. it forks for calls only for SMS its not yet there but its on company To-Do list
iOS solution in some time.....kind of busy now
One of the very good post by Genius as usual (but without any smart pics).
Check out my below post too for solving this +91 issue permanently by installing Number Fixer app which will replace all +91 with 0.
Link :
Link to Number Fixer App : https://market.android.com/details?id=com.maplekeycompany.apps.numberfixer&hl=en
Share any File / Folder from DropBox via direct link
Drop Box allows sharing only via email invites or to share files in Public folder there is no option for Sub Folder in Public folder sharing here is a small trick that will give you right click link to any file/folder in DB
all you have to do is click in this link after you logon in DB account
https://www.dropbox.com/enable_shmodel
DOne..... you will have a new right click menu with added link and also on left panel you will have option of links.
when you click the link there is a option to download as a Zip and to put it directly to your DropBox account too
now thats amazing - right
  • Like 4
Yey. Forbidden Fruits always taste better!!!
Thank You very much for sharing this Vinay Bhai,,,,
I had a problem in Tata Indicom,,,
Incoming calls from Vodafone, Idea and BSNL network used to display as +0091, and my device could not pick up the Caller's name from my contacts, it used to show as unknown caller.
Now using this app I can see the callers name...
Thank You again....
Genieus dialer link not working. Please update.
Get this
GeniusDailer
iTunes
Video:
^^^ Google it even I don't know and past it
I am out for few days can't search
Thanks for the Dropbox trick its very usefull
Android
Link : http://www.rimweb.in...post__p__253924
Link to Number Fixer App : https://market.andro...mberfixer&hl=en
This is in continuation to this problem, myself & Genius have found a new solution.
If you save all your contacts in the format 009193xxxxxxxx then there wont be calling / sms / phone book / name display issue in any android / ios device.
This is tried & tested by myself / genius & found to be working on RCDMA as well as GSM.
Others can post their experience here..
+1 if it helped you...
Hi Rimwebbers,
At my home , my brother has two sons, now the problem is when i Keep my cell/tab for charging, they would just pull it out and start playing , although they are just 4 years and 2 years.They just Love ANDROID lolz.
Now back to the point , I saw some websites selling these Riona Mobile holders worth 99,145,199 etc...I was gonna purchase it when I came across this website .
It has DIY Mobile charger holder, And so i tried making one myself. For instructions you can check that website.
And for my wonder you can look down.It took hardly 30 minutes to make.But its cool :)
Let me know if you liked it :) Its not as good as the website one but still , I am feeling about the thing. Please try this and revert to me with your creation :)
Stuff Required:
Bisleri Bottle or any other durable bottle.
Scissors
Glue for cloth or newspapers [if you wish to decorate.]
Sharp Cutter
If you are using bisleri bottle, try to paste card board on both sides [in n out] before applying gift wrap or cloth :)
Thanks for reading
Comments welcome and I am waiting for them.
post-24057-0-03931700-1350558080_thumb.j
post-24057-0-31365100-1350558088_thumb.j
post-24057-0-86194500-1350558095_thumb.j
post-24057-0-77293300-1350558104_thumb.j
post-24057-0-77480400-1350558112_thumb.j
post-24057-0-89720000-1350558122_thumb.j
post-24057-0-58529400-1350558136_thumb.j
post-24057-0-26747900-1350558143_thumb.j
post-24057-0-43191300-1350558148_thumb.j
  • Like 6
mast DIY..
triggered from tappa-talk 2...
