rvksp
Please Suggest Me a CDMA Phone With MP3 Player Around Rs.3000
Basic requirment is only good mp3 player,with external memory card support.Currently i am using handset Samsung
SCH-B259 cdma phone.I am confused with terms like OMH..Currently i am using cdma sim,will that is not compatible when i buy OMH Handsets..??
plz,give opinion regarding:
Samsung B519 CDMA and Samsung Mpower Muzik 219
will my current sim is compatible on any of the phones?
Your present RUIM is compatible with OMH handsets and will work fine - in the sense you will be able to use the basic call and texting functions.
OMH (Open Market Handset) card, which will cost you Rs.100, is for provisioning Data setting like EVDO and operator content on your phone. If do not intent to make use of data, go ahead with the present one!
Friend, If you can add Rs.800 to your current budget can buy LG 6300 - a good MP3 handset with 2.1 sound output and external memory card. Please see this link
please see the full specifications from here http://www.lg.com/in/mobile-phones/all-phones/LG-LG6300.jsp
I am using Mpower Muzik 219 from last 4 months, its working fine. Sound quality is great. Phone does not have any issues/problems. Its supports external memory card upto 2GB only and you can't play music in background and it has VGA camera only. 2nd, your UIM (means CDMA SIM) will work with any OMH. I am using TATA Indicomm on my Samsung.
samsung muzik series is really good for Mp3 and satisfy all your basic needs. there are 2 models in this series, 219 and i think 317. 317 is older one. my dad has 317 and its really good.
LG RD 6150 solid mp3 phone with 4 GB sd card.dont search beyond this.
