aniket_jain22
How to Access Reliance GPRS on PC From Nokia 6233?
Hi All,
Can any one tell the procedure to connect Nokia 6233 to PC via data cable to access Reliance GPRS
It will be great if someone can tell to compete procedure from mobile and network setting
This will be great help
Thanks & Regards,
Aniket Jain
Edited by aniket_jain22
You can internet through bluetooth DUN.Easy and convenient.No need to install drivers for cable.Keep the phone near window where signal are more and keep distance 5-7 mtrs
