deepv84
Please Suggest Me An Android GSM Handset among these options
guys i want to buy an android gsm handset
some i have shortlisted plz tell which one to buy
1.dell xcd28 = rs 5999
2.spice MI-310 = 7300
3.huawei ideos = 8500
4.samsung galaxy 551= 9000
or any other but i don't want to invest a lot money .
does dedicated graphics chip works better ?? (lot of samsung devices don't have )
specifications are below.
u can go for galaxy pro or optimus p500
my freind is using optimus & quite satisfied with is performance
Edited by parin
i am using galaxy .. the phone is good.
which galaxy bro??
Deepak if you can be more specific about your price and requirements we can help better but optimus one p500 and Galaxy 551 are the options I suggest in the given price range. These phones have 2.2. Here is a comparison http://www.gsmarena.com/compare.php3?idPhone1=3516&idPhone2=3515 .
Galaxy 551 has QWERTY keyboard. If you need hardware keyboard then this is only choice.
Optimus one p500 has been very successful worldwide and good value for money.
XCD28 is in similar price range but has resistive touch screen and 2.1.
I would not suggest spice MI-310 as it is budget phone and screen and battery and camera are lower specifications compared to others mentioned by you.
Galaxy fit is another phone just above this price range.
If you go through the GSM handset suggestions forum there are topics detailing most of these phones.
Edit had replied from office so could not see you have already posted comparison.
Edited by dipanlahiri
ok thanks guys !!!
