dacodecz
Cdma 2000 Traffic Sniffer.
Dear friends,
Anybody here aware of anysort of traffic sniffer that can be used to capture and dissect CDMA 2000 traffic between there BST and phone, well ethereal can dissect the CDMA 2000 / 1x traffic but it cant capture the same, until unless one have some drop in box between the phone and signal it's receiving, it's usage is useless.
I want something like this...
|BST| ======|Sniffer| ======== | Phone |
                                        ------>| Ethereal on a pc |
I hope I will get some information from here.
Cheers ..............
i'm sorry for 4 years gap... was searching for the same and i found that it's possible to capture the traffic but for that u'll ned a RF generator that can generate signals stronger than the BTS..... but there is one more thing if you are looking to sniff traffic of one perticular mobile than you'll just need a signal strong enough for that mobile to connect to you (you have to be close to the mobile)..... for more info PM me may be we can work together i'm searching for informations tooo....
