raj_raj_in_in 1 Report post Posted May 22, 2011 Hi, Pixi is not turning ON... dont know wat the problem is... and yes battery is charged too. Tried USB mode too but nothing comes up on screen, nor PC is detecting it. Have removed battery and reinserted it..but no luck. 2 days back I had upgraded it to 1.4.5.1, can dis lead to my prob? have kept it on charge right now hoping for something... Help me.. Share this post Link to post Share on other sites
drmadhu 87 Report post Posted May 22, 2011 After upgrade your version u can able to start your mobile or not? Share this post Link to post Share on other sites
raj_raj_in_in 1 Report post Posted May 22, 2011 after upgrade I used the mobile without any problem for 2 days. Today all of sudden, after the charge phone has gone dead. Even webos doctor isnt detecting the mobile Share this post Link to post Share on other sites
@mitJ@in 256 Report post Posted May 22, 2011 same happened with me, my phone became dead... Share this post Link to post Share on other sites
drmadhu 87 Report post Posted May 23, 2011 ^^ your phone is going to usb Big icon mode or not? If going try reload other rom. Share this post Link to post Share on other sites
raj_raj_in_in 1 Report post Posted May 23, 2011 ^^ your phone is going to usb Big icon mode or not? If going try reload other rom. No.. nothing.. phone is just not responding... Would have reloaded it with older Rom had it been displaying/respond to something.. Just dont know how can phone goes dead on its own all of sudden. Share this post Link to post Share on other sites
raj_raj_in_in 1 Report post Posted May 23, 2011 same happened with me, my phone became dead... Hi Amit, Was going thru palm support forum and found this thread, may be u could try the paper trick to your mobile. http://forums.palm.com/t5/webOS-Hardware/Palm-Pre-Plus-Won-t-Turn-On/td-p/298301 I will try it once I reach home tonite let see if dis trick works ..lol Share this post Link to post Share on other sites
raj_raj_in_in 1 Report post Posted May 24, 2011 No yaar.. piece is just not working.. Any suggestion guys? Share this post Link to post Share on other sites
parin 857 Report post Posted May 24, 2011 Show it to Some local mechanic he can detect if any problem of IC or something else 1 Share this post Link to post Share on other sites
drmadhu 87 Report post Posted May 30, 2011 Can your problem id solve or not? Sent from my SCH-I500 using Tapatalk Share this post Link to post Share on other sites
ankurcshah 112 Report post Posted June 10, 2011 Hi,Any updates if you have found a solution for it? Share this post Link to post Share on other sites
raj_raj_in_in 1 Report post Posted July 26, 2011 Sorry guys... wasnt following this thread ... will show it to local repair soon and will update Share this post Link to post Share on other sites
