digitalnirvana
Beginners Guide To Android
@Abhi. Sms backup and restore by ritesh sahu its free on market. For contacts export to sd card in .csv format. Should be under settings most roms have it
Thanks dipan bhai,
this is what i do..
created a Titanium backup pro
created a clockwork mode backup
installed Syndicate Frozen Rom 1.1.1 (xda) (based on EC05)
tried to restore apps/data from titanium backup pro.. but it got stuck every time i run restore (missing apps + System data)
only 1 app used get installed and titanum backup progress bar froze.
so now im back to my stock EC05 (restored from cyanogem mod) untill i figure to restore apps/contacts/sms from stock to syndicate
Abhishek,
Open TB and before restoring anything click the menu key. Now click Preferences, App Installer Mode and change that to Auto INDIRECT, by default it will use Auto, Direct. Now try to run a batch restore.
Also I strongly recommend when you take TB backup take app and system data backup separate and restore separate, as restoring system data often causes battery drain on Syndicate.
Also are you separately backing up contacts, call logs and SMS because TB does not backup those. Use my backup pro for all, or SMS backup and restore for SMS, and google sync/g-backup full for contacts and call logs. All are on the android softwares thread.
Edited by dipanlahiri
yeah, now even I find google sync the best tool to take backups for contacts.
but how to get backup of those contacts to google account which i saved only in phone's memory?
Very very commendable effort Dipan. Kudos to you...
after spending hours backing up apps and contacts and linking all contacts manually..... figured that microphone didnt worked :(
so back to stock EC05 (the best for noobs like me :D )
Abhishek why did you need to backup contacts manually bhai, google sync is easiest way just signin to your Google account and it does it.
If you want to have an alternate option, try my backup pro for contacts/SMS/call logs/homescreen settings etc., extremely simple GUI interface, and it also allows backing up online. Worth the 250 INR but apk also on forum.
Regarding SRF not having microphone, what is the exact issue? And I guess it is better to post the Epic specific issues in the Epic thread. Let us keep this thread for general Android OS.
Sougata da thanks.
Vinay ji thanks for the guide.
How to delete old nandroid backups?
Sorry dipan to reply in your thead ::::
To delete old nandroid go to sdcard > clockworkmod> backup
There u will find few folders, each folder contains backup date and time wise
BTW I am looking for good tutorial on editing framework-res.apk
Kalpak sir why sorry this is not my thread it is open for everyone.
For framework res do you want to mod anything like icons? Best way is on UOT kitchen, meantime I will search for guides.
Thanks, I want to make battery icon mod for showing battery in %, I tried yeserday but failed.
Dipan, thanks for UOT kitchen, its so convinient.
I found reason for framework-res.apk problem - it needed to be zipalign-ed
But neatness I got from UOT kitchen was not there in my png edits.
++++++++++++++++++++++++++ for Mr.Dipan Lahari
Pls. suggest good Android App for 1) Voice Tag / Dialer 2) Call Recording
Can't say if it should be a part of beginners guide.
But found it useful, you may need it sometime.
Ever bothered to see the contents of your Nandroid Backup, i.e. the img files created during Nandroid (data.img, system.img)
Here is a small guide and application "unyaffs-x86-win.rar" for that.
Download the attached file and extract to any folder on your PC.
Place the "img" (data or system) file in the same folder where the file "unyaffs.exe" is placed.
Go to command prompt on your PC (windows->run->cmd)
Go to the path of the folder where "img" file and "unyaffs.exe" are placed.
Run "unyaffs", all the contents (data/app) of your "img" file will be extracted to that folder.
  • Like 3
@ admirer2000
None call recorder is reliable on android because of ANDROID's limitation
  On 6/20/2011 at 9:45 AM, kshah said:
@ admirer2000
ho :'(
Any luck for Voice tag / caller?
:signthankspin: in advance.
thank you kshah.
+1 for your help
does any one know how to see call log while still on call - its not possible in samsung galaxy sets
have not tried any 3rd party though
Call history is possible on my EVO...
in call ==> press Home, all apps, call history or people, history..
Recording of call conversation. not call history.
:previous: doc, am not able to d/l, don't know why, whenever i click on "Slow Download" nothing happens.. can you pleae upload it on multiupload
AAlok its working - just checked it, you need a Ffx or ie browser does not work with phone or ipad browser, if not i shall re-upload it.
