kesav 127 Report post Posted June 10, 2011 TCL launches world's first OMH EVDO USB modem -- X080C http://www.omhworld.com/devices/tcl :clap: Share this post Link to post Share on other sites
@mitJ@in 256 Report post Posted June 11, 2011 First was AnyData USB Modem. It cant be first. Share this post Link to post Share on other sites
ssk the gr8 2 Report post Posted June 11, 2011 where can i buy it? Share this post Link to post Share on other sites
ravi_patent 28 Report post Posted June 11, 2011 where can one buy either of them . Share this post Link to post Share on other sites
kesav 127 Report post Posted June 11, 2011 First was AnyData USB Modem. It cant be first. I feel Anydata and Micomax modems are RUIM based but not OMH complaint. Means EVDO parameters are picked from Modem memory and not from RUIM. They normally come with all possible operators' settings when released in respective geography. For example, Micromax(300C) modem comes with all Indian CDMA operators(BSNL,TATA,RCOM & MTS) EVDO settings pre-programmed. Suppose, if you take this Micromax(300C) modem to Bangladesh/Pakistan/Indonesia, it may not work with that country's CDMA operator's RUIM since those operators settings are not pre-programmed. 1 Share this post Link to post Share on other sites
me_saket 73 Report post Posted June 17, 2011 First was AnyData USB Modem. It cant be first. I feel Anydata and Micomax modems are RUIM based but not OMH complaint. Means EVDO parameters are picked from Modem memory and not from RUIM. They normally come with all possible operators' settings when released in respective geography. For example, Micromax(300C) modem comes with all Indian CDMA operators(BSNL,TATA,RCOM & MTS) EVDO settings pre-programmed. Suppose, if you take this Micromax(300C) modem to Bangladesh/Pakistan/Indonesia, it may not work with that country's CDMA operator's RUIM since those operators settings are not pre-programmed. micromax 300c device is used by me from last 8 months. it reads OMH and non OMH sim correctly. IF u use non omh sim, then it shows only 1x coverage and if use OMH then EVDO coverage. but it might true that it may had PRL setting in built in modem. Share this post Link to post Share on other sites
