baskhit
Please suggest between BlackBerry 9630 or 8530?
Rim Gurus, need your suggestion on the offcial reliance blackberry handset buy. 9630 or 8530? my expectation is good battery back up and durability. Not sure which one will have better life track ball or trackpad?
undoubtedly, 9630.. world phone capabilities.. can be unlocked for GSM in less than Rs. 500.00.. regarding trackball, replacement is till the life of handset, free of cost, by reliance..
sent from my AnDRoid6300 using tapatalk...
Thanks Aalok for your valuable suggestion.
9630 : dual , trackball , can be unlock to any gsm but it would void warranty .
8530 : trackpad , only cdma
Edited by supernova
@Supernova BB 8530 comes with a trackpad.
Go for BB 9630 - more juice in battery, better cam, higher resolution display, faster data transmission (EVDO Rev.A v/s Rev.0 for BB 8530) and as Aalok pointed out -It is a world phone and can be unlocked to be used with GSM.
9630 misses wifi
Only minus point
Go with the 9630 hands down its a work horse phone. I still miss it having shifted to 9650. Go for the tour without hesitation. You won't regret it plus its battery capacity is much bigger the than 8530 so you wont have to worry abt the battery too !
Thanks guys I have decided to go with 9630. comprimising the wifi & trackpad. But how about 9650 is it better than 9630? please suggest.
yes 8530 with trackpad . typ error . editing
  On 6/15/2011 at 5:07 AM, baskhit said:
how about 9650, is it better than 9630?
Anyday! BB 9650 fixes the drawbacks with 9630 - you get an easier to navigate trackpad instead of trackball, comes with wi-fi (which is an essential for smartphones) and the internal memory is doubled to 512Mb.
