Can anyone help me how to install the drivers of LG LSP340e model FWP in Windows 2003 Server??
Help needed urgently??
Thanx in advance.
Pradeep Surana
GMS Computers
Disty. of Enjay ThinClients in Rajasthan.
09351171281, 0151-3095431
Go to Add New Hardware wizard and install a Standard 19200 bps Modem, and after installing it add AT+CRM=1;$LGPKT=3 in its Extra Initialization String.
And then make a new Dial-up connection and enter phone no. as #777 and ur phone no. as Username & password (Without leading zero).
Thats it!
Thats it!
26828[/snapback]
I tried with that but was not successful. With these extra settings the modem detects but when trying to connect through it doesn't works.
Did u set the Data Baud Rate in the phone to 115,200?
U can do that by pressing MENU+2+4 and select it.
Thats it!
26828[/snapback]
26846[/snapback]
After setting the Data Baud Rate to 115200 only the modem detects. Otherwise not.
so you are thru...thats great vj...enjoy...
what error are you getting when you try to connect ?
It only detects but does not connects???
26988[/snapback]
Dear gsmcomputers,
Can you send me your modem log. You can find it in WINT/WINDOWS directory.
Cheers ..............
