enjoylifewithsms 3 Report post Posted June 29, 2011 Hi I am planning to take data card but I am confused.The most cost effective is MTS.But I doubt its reliability So would like to know which one is better TATA/MTS/MTNL 3G or any other 3 G operator data card. I need constant speed with high reliability Share this post Link to post Share on other sites
shrik 9 Report post Posted June 29, 2011 This is very location-dependent so suggest you borrow data cards of different companies from friends or sales people to check their performance at the sites you will be using the internet, before you buy one for yourself. Share this post Link to post Share on other sites
Nirvana 4 Report post Posted June 29, 2011 Are you going to use it at a particular place (like your home) or when traveling around? If you are going to have most usage at a particular plan then check for the signal coverage at that place. The signal will have a good effect on the speed that you will get. So which operator has the best signal in your place is the best one for you. Share this post Link to post Share on other sites
amitnsonu 72 Report post Posted June 29, 2011 just try one thing take an unlocked gsm data card, put a Reliance GSM sim in it. recharge with 29 (it gives u 500 mb for 7days on 2g network). then try to use this on 3g network. it will be cheapest option if works... speed on reliance 3g is awesome because lesser number of customer. Share this post Link to post Share on other sites
