pasumark
Best Wireless Broadband Data Card For Chennai and TN
As I will be travelling to Chennai often, I am planning to buy a Data Card for my laptop. Please suggest best Data card. Also I may go to other tourist destinations. Thanks in advance
Reliance only
alcatel data cards are best in my opinion. check @ letsbuy
dont buy micromax, too much complaints in the cards
Reliance is best in TN in coverage as-well in speed too.
Please be specific CDMA or gsm platform
Best card in terms of looks functions coverage ?
incomplete questions will get incomplete answers
Go for unlimited data.
BSNL cdma 1x unlimited Rs 250 per month
BSNL cdma 1x unlimited with roaming (India) Rs 350 per month
Reliance datacharges cdma 1x are high.
BSNL NIC datacard available at Rs1100
For speed
Reliance Net connect+ at Rs 750 per month
BSNL EVDO unlimited Rs 750 per month
Both datacard available at Rs 1500
i believe kumaarshah/kanagadeepan are the most knowledgeable persons in this regard.although i didnt use yet,i feel reliance evdo will be good undoubtedly in chennai
Edited by ravi_patent
Well it can be any CDMA or GSM. I am expecting speed and reasonable tariff. My usage will be only when I am on the move. In home I have wireline with wifi
Thanks for your immediate response friends.
So based on your advise, I can go for Reliance I think.
Thanks a lot
Thanks Ravi...
Unfortunately, I use MTS only and not RCOM or TI for that matter. And my usage is mostly in Chennai only. Or maybe the top metros. As far as interiors are concerned, I believe Kanaga Deepan should be able to help out pasu. In Chennai, the MTS network is good but the speeds are not all that encouraging and there are ups and downs. And I haven't used the data card for the last 2 months or so, so my opinions/remarks may not be that valid.
For tn and chennai reliance netconnect+ is good..
I have Reliance Netconnect BB+ and I have used it in almost all the remote places in INDIA..coverage wise no complaints to be frank. In my home network I have only problems with speed.. I dont get more than 1 mb speed anytime.
CDMA Broadband+ has covered all major places and districts speed is good... Even in GSM EDGE is working fine...
Sorry for the VERY VERY late attendance this time... I have been busy three days...
SPEED + CHEAP Tariff:-
Ganesan sir, in Sivakasi MTS rocks (even comparing RCom NetConnect+)... I am getting speeds upto 2Mbps max almost everytime... They are having more EVDO towers than RCom and TATA... Please use "Broadband Mode" and avoid using "Hybrid mode" while NOT in move, as you may get lesser speeds... Even while travelling in train, I use "1x mode" than "Hybrid Mode"...
COVERAGE:-
So reg speed, MTS is good... But when it comes to coverage, RCom is the king... I think our VNR district is almost having BLANKET_COVERAGE of RCom EVDO... Even BSNL is poor when comparing EVDO coverage of RCom in TN....
GREAT SPEED + CHEAP Tariff + ZERO_RELIABILITY:-
BSNL 3G and EVDO... No more words are needed to explain why...
@kanag sir, true i think rcom evdo coverage is better even than bsnl 3g. I'm in mayiladuthurai. Only evdo available here is rcom. Infact, only 3rd gen option available here is that.
Thanks friends. Based on your suggestions, I have decided to purchase Reliance netconnect+ pre-paid. I mainly would be using it while away from home town - mainly in chennai, etc.
BSNL 3G and EVDO... No more words are needed to explain why...Kanaga
:Contento: :Contento: :Contento:
Edited by pasumark
Astounding :clap: .Is MTS delivering such speed in all places?
:previous:
Obviously NOT everytime/everywhere... But in my hometown, I have never got low speeds like 800kbps or 1Mbps :winko: ... Minimum I am getting 1.5Mbps speeds... May be due to very few users in my area...
But in my friends home (very near to tower) he always get around 600 to 800 kbps speed only...
I have purchased Reliance Broadband Netconnect+. I am very happy with the performance.
Last week I was in Ramnad(TN) and the speed was good. And this week I was travelling to Chennai in car and at 2 places I needed to randomly stop my car and connect to net. At one place it connected in full speed and in another in 1X speed. In both places, I could finish my work without any problem.
Thanks for your suggestions guys
I will be mostly in Chennai for next months. I am already having a Reliance Netconnect +. Is it the best wireless Internet option or are there any other better?
Check Aircel 3G on unlocked modem...
I will be staying near Valluvar Kottam. I will check their coverage there and then check their speed.
Thanks Kanaga
Bsnl EVDO, I have checked coverage in OMR, Tambaram, and Perumbakkam areas on my last trip to chennai, speeds are always above 512kbps, at night around 2mbps in torrents
