me_saket 73 Report post Posted July 20, 2012 What do u mean by network card? u can use usb port for connecting internet via ur wireless router. u need to put wifi dongle, for details contact cc Sent from my HuaweiU8300 using Tapatalk Share this post Link to post Share on other sites
csmart 472 Report post Posted July 20, 2012 Network card = ethernet connector, 10/100.. I will try wi-fi dongle. Sent from my SPH-D700 using Tapatalk 2 Share this post Link to post Share on other sites
vikasmahajanz 33 Report post Posted August 18, 2013 Dear Friends, I seek your Kind Suggestions Please.... I am Planning to Buy a DTH Connection but Bit confused Between these 2 : 1. Videocon D2h HD Video Recorder OR 2. Tatasky HD Plus My Requirements : 1. DTH should serve best quality and More HD channels... 2. Reception and Quick Performance Quality of Set-top Box should be good enough , Currently I have Reliance HDR which I am not satisfied with Many times its response is very slow.. 3. Cost Effective Package. 4. Recording Options (Like Via sms or Via Online Login) 5. More Recording Space 6. To Be Used with FULL HD Plasma TV 50" 7. Should work in normal Rainy Season also 8. 3D Ready 9. New Timely Offers... 10. Main Point is Quality of Response of channel change should be quick and should serve some Cool Extra Ordinary Features 11. Cost of DTH Box does not matter... I hope I will be getting a satisfactory Information so that I can decide to go for the best DTH... Regards Vikas Mahajan Share this post Link to post Share on other sites
cdmaexpert 2 Report post Posted August 18, 2013 Tata is best At least Tata. Hd plus box. Works. Better than. Any other. They. Use. 2 cables. From lab to reciver box. . Works in good rains. Drops. Less than. Dish or airtel or big tv. Share this post Link to post Share on other sites
city02 63 Report post Posted August 19, 2013 no dth will work in 'normal Rainy Season' so set your expectation accordingly for pixelation during heavy rains the benefit of a recorder is that you can keep watching your recordings even when there is no signal due to bad weather as long as you record some duplicates of your fav shows like we do, you'll be fine during monsoon even if a particular episode has poor quality / freezing up, you can just delete it and watch the 'backup' [repeat telecast] we have airtel and tata recorders, TS+ seems to be the best one currently my parents have dish which is quite bad with customer service so you should avoid Share this post Link to post Share on other sites
csmart 472 Report post Posted August 19, 2013 Tata Sky is consider to be the best but it does not have all the HD channels. TS is the last one to get any new channel. Packages are cheaper on Videocon than TS. Below links show user comments from other forum: http://www.techenclave.com/community/threads/videocon-d2h-hd-or-tata-sky-hd-please-help-me-decide.148363/ http://www.techenclave.com/community/threads/videocon-d2h-instead-of-tata-sky-hd-please-help-me-decide.136530/ Share this post Link to post Share on other sites
MOBILE FAN 42 Report post Posted August 19, 2013 I m using airtel dvr for last 3.5 yrs. and very satisfied. But I would suggest Videocon because they have available space to add any new hd channel. Sent from my XT800 using Tapatalk 2 Share this post Link to post Share on other sites
kshah 452 Report post Posted August 19, 2013 Airtel is good but with only problem of quick signal loss in case of slightest rain. In Ahmedabad out is not a big problem though. Share this post Link to post Share on other sites
Deepak Shankar 79 Report post Posted August 20, 2013 I have been using Videocon HD for 6 months now pretty much happy cheaper than rest esp Tata and quality is quite good Rain signal is associated with all DTH but here the loss is for a matter of few mins that too incase of heavy rains only even when it is bright and sunny I had no signal issues with TS.My suggestion pick Videocon Share this post Link to post Share on other sites
vikasmahajanz 33 Report post Posted August 25, 2013 thanks Guys for your suggestion :) I have decided finally to go for Videocon D2H DVR Share this post Link to post Share on other sites
vikasmahajanz 33 Report post Posted August 31, 2013 I have finally Planned to Buy this latest model of Videocon with 1000 GB Capacity to record http://www.videocond2h.com/wsc/videocon_d2h_unveils_indias_first_1000gb_hd_dvr.aspx Share this post Link to post Share on other sites
pasumark 51 Report post Posted September 1, 2013 ^^^ Price of this DVR? Share this post Link to post Share on other sites
