anshu_s09
Help Required with Bettel 3G data card
i am having a BSNL 3G Postpaid Sim and i am using it on unlocked datacard of BETTEL, but its not working, whereas all other sims of airtel , aircel mtnl are working properly. i think it might be bcoz of roaming. i need to save the, dial number and apn before connecting to the network. i have saved *99# as dial number and bsnlnet as APN
Kindly help me to get it connected in MTNL Delhi.
in Bettel 3G data card we 1st need to manually save the dail number and apn for once then we can connect it.
Can you see MTNL 3G network there by manual search? Try to register to MTNL 3G or Dolphin 3G/HSPA network.
Mtnl 3G coverage is scanty and non-searchable in some areas of Mumbai. Its a lil pain initially to fix bsnl roaming over Mtnl Hsdpa.
Sent from my Nexus One using Tapatalk
network is there it is registered but not able to get connected
Edited by anshu_s09
i mean what error u get?
did u try query modem & put in extrainitialization command
at+cgdcont=1,"ip","bsnlnet"
