weapon-x 3 Report post Posted July 17, 2011 Hi , guys i have Touch Pro 2 with me since last few days there is an issue with my mobile ........ 1. If display Goes off , i can get it back online with power button . 2. can hear any thing from speaker , have to switch to loud speaker or use hand free to hear the calls . 3. need to pull the battery out and then have to start it again .. I took the phone and checked it out with a local guy he said ... every thing is fixed on single ( PATTA ) , i have to get it replaced .... is this really the issue plz help out .... if u guys know any gud mechanic plz share ... thanks in advance . Mohit Share this post Link to post Share on other sites
KapilAgrawal 340 Report post Posted July 17, 2011 @ Mohit 1. If display Goes off , i can get it back online with power button . ---- Please Clarify. Generally TP2 goes to sleep mode & you have to press Power button (on left top) to get the screen back. 2. can hear any thing from speaker , have to switch to loud speaker or use hand free to hear the calls. ----- If you cant hear from the Handset earpiece while loud speaker works, Issue is with the earpiece. 3. need to pull the battery out and then have to start it again .. ---- For what reason ??? Share this post Link to post Share on other sites
weapon-x 3 Report post Posted July 17, 2011 @ kapilthio 1. yes even if i try to press the power button it doesn't come online ... 2. yes ear peice got the issue ... 3. As the phone is in sleep mode cant make any call .... so need to restart the phone via pulling the battery out ... Share this post Link to post Share on other sites
::Hitesh:: 1,763 Report post Posted July 17, 2011 ^^^ For 1st and 3rd issue u can try flashing stock rom, it may help Share this post Link to post Share on other sites
