tanveer
Sequential Stills
I have a GTRAn and a 7230 and both of them can have animated wallpapers but a sequence of stili images is required to make it look like animation. Where can i get such images from? and also is there any software using which i can make stills from AVI or MPEGs so that they can be used for the above purpose? if anyone has such files can u share it?
26947[/snapback]
If you have mplayer, you can do
mplayer movie.mpeg -vo png
or
mplayer movie.mpeg -vo jpeg
to get frames
try mplayer -vo help to get all options.
or you can get mplayer at www.mplayerhq.hu
try "Easy GIF animator" tanveer...works like a charm..
i've got a buncha home_animated clips on my cellphone now...
u can animate sequential gif pictures into a mini-movie-clip kinda thing and export as avi and other formats
for the actual "caps" (sequential images) try LINK REMOVED....some pretty interesting scenes in there :(
cheers
I got Samsung A603, any idea on how to add animated wallpapers??
ooops... :(
edited:
....that was for the deleted link :'( ...
greens, im not sure about ur exact model, but if it displays any kinda animated pictures and stuff, it probably will handle the gifs u animate with easy-gif-animator...provided it has options for the pc-to-cell transfer...
Edited by rEdshiFt
