pranayshah 0 Report post Posted July 25, 2011 Hello, I have just bought an UNLOCKED PALM PIXI PLUS from the United States and am desperate to use it on the Reliance GSM network. What is wierd about this is that once I put in the Reliance GSM card, I can't move onto anything until I enter the following information: Internet APN: which I was told by Reliance is rcomnet Username: Password: now for both the above fields, reliance tells me that its blank however, when I hit CHANGE SETTINGS it tells me Unable to Write Settings. What is wierd is when I try to make an emergency call, I can dial any number I want and talk on tha tnumber for hours.. that's no problem. Also, I have no idea how to get out of that screen so as to enable me the Menu of the phone. Can someone please help ASAP. Thanks. Share this post Link to post Share on other sites
@mitJ@in 256 Report post Posted July 25, 2011 I think you need to install bypass rom. Share this post Link to post Share on other sites
rahulpadron 0 Report post Posted July 27, 2011 Hi, I've been facing problems with setting up gprs on my Palm Pre. If anybody using Rel GSM prepaid, what are the proper settings for GPRS?? Whenever I try, it says settings not registered. Share this post Link to post Share on other sites
::Hitesh:: 1,763 Report post Posted July 27, 2011 Palm gsm users, try installing TREO8 bypass roms [non china mod roms, (china mod roms = sms problem) ] Share this post Link to post Share on other sites
rahulpadron 0 Report post Posted July 29, 2011 Palm gsm users, try installing TREO8 bypass roms [non china mod roms, (china mod roms = sms problem) ] Thanks, any link to download this. I'm really not familiar with this. Share this post Link to post Share on other sites
rajendra.jindal 0 Report post Posted April 27, 2012 Hello Palm pixi GSM users , I can activate GPRS by providing permanent Internet settings on Palm pixi Plus. U can contact me for the same. Share this post Link to post Share on other sites
amitnsonu 72 Report post Posted April 27, 2012 please explain here.. all other members will be benefited including me. thanks Share this post Link to post Share on other sites
