prat
Wats The Spc Code For 6130 In Qpst?
I have not been successful in using QPST for my 6130. It keepas asking me for SPC code. It's not 000000.
Can anyone help??
Prat
use bitpim to read SPC
Thanks dude, but please also tell me how to read the SPC using Bitpim. SOmeone said its under the nvm folder. Can you be a little more specific. I can find no 6 digit number under this directory.
I hope you have a 6130 coz things dont work the same for all fones.
it is in file nvm_0000 in folder NVM or NVM/NVM. you will find 1 or 2 6 digit code. One of them is SPC
27113[/snapback]
can you tell me how to reach the spc in lg2030 what is the progrmmingprocedure for lg 2030
MENU + 0 + 9
this doesnt work with s/w versionm RD203F15
I tried this. Under nvm_0000 there is a 4 digit number. Under the entire nvm directory, there is no 6 digit number. All are one, two or four digit no's. None of them is the SPC.
I have a 6130 btw
I also tried to first use UniCDMA. I ran LGKDP, then UNICDMA, HF to DM mode. It worked ok. Then I tried to run QPST, it asked for SPC.
I also ran BitPim, but it gave some errors, or exceptions.
Please help me, how to get this SPC, can I download some tool to get SPC from the ESN?
Thanks in advance!!
Rohit Rohela
