mroy
Nokia 6275 - No Sound
A strange problem has occurred. My Nokia 6275 has gone all silent. It is not ringing, no message tones, nothing. Keypad tones are audible.
Before anyone suggests it, I have checked that my phone is not in silent mode.
Any suggestions?
Can u test, calls on speaker phone ?
Yes, I tried. No sound. I can hear through handset though.
Just check if you see the h/f sign even after removing the h/f. If yes, you need to replace the h/f socket...
I am not using handsfree.
Can u hear sound of 2nd person from speaker ?
Also check Handsfree icon as said by Rajani
No, I cannot hear sound of second person through speaker.
Also, no handsfree icon and also I do not use handsfree.
then u need to replace / repair speaker of your phone.
it can be done for few bucks in local repair shop, nothing big.
Thanks, I will try this and give status update when done.
While I was trying to find a local mobile repair shop, my mobile's speaker came to life all by itself and is working perfectly now.
Madhabi
If speaker is faulty then how can you hear keypad tones as per your first post
I don't know what the fault was - as per the original post, I could not hear ringtone (for incoming calls or while trying to change ringtones), message alert tones and alarm clock. Also, when a call was in progress, if I switched to speaker phone mode, there was no sound.
Anyway, the problem has been solved and it is working fine now.
Its good to hear that the problem has been solved
