SaketBajaj 0 Report post Posted August 18, 2011 Hi, I bought a Samsung Galaxy S2 phone last week for my Reliance GSM connection, and after inserting the sim, I found that it says "No Network". I checked with other networks like Airtel, Vodafone, Uninnor, etc they all work perfectly. As soon as I inserted the sim card and switched on the phone, the network was detected. But with reliance sim it is not detecting the network. I went to reliance web world, and an employee check all the available sim's and the same thing, it does not work. The reliance sim works perfectly in other phones, but not in samsung galaxy s2. Anybody, is facing similar problem kindly help out. Thanks. Share this post Link to post Share on other sites
@mitJ@in 256 Report post Posted August 18, 2011 No such issue found. Upgrade the Firmware to latest one. Share this post Link to post Share on other sites
SaketBajaj 0 Report post Posted August 18, 2011 No such issue found. Upgrade the Firmware to latest one. I have Android 2.3.3 Installed from factory with these details as below. Kernel 2.6.35.7-I9100XWKF3-CL276555 root@DELL101 #2 Build Number GINGERBREAD.XWKF3 Kindly suggest if there is any new firmware. Thanks. Share this post Link to post Share on other sites
RiteshDharod 5 Report post Posted August 19, 2011 And I can't upgrade my Rom from settings through About via Samsung. Anyone else facing this Upgrade problem? Sent from my GT-I9100 using Tapatalk Share this post Link to post Share on other sites
SaketBajaj 0 Report post Posted August 20, 2011 Hi, Checked reliance sim with another galaxy s2 handset, and its working perfectly.... So, definitely my handset was defective. So, filed a complaint with Samsung Service and got a replacement certificate for issue of another new handset with fresh warranty. This took some 3 hours to complete as the service supervisor tried to convince me for servicing the handset, but I insisted for a replacement. And finally got the new handset today morning from the retailer I bought from. This is just for knowledge of members that Samsung only accepts defective handsets for replacement up to 4 days from date of purchase. Mine was an extreme case with 9 days.... but got it solved. Thanks to the supervisor and samsung. Share this post Link to post Share on other sites
