RavitejaSrigiriraju
Unable to transfer files between Samsung Epic and PC
i bought a samsung epic recently, but i am unable to connect it to the computer, my computer doesn't recognize but my epic turns yello from geen indicated the connection, i am unable to transfer my files :(
Are you sure you changed from "Charge only" to "Disk drive" after connecting?
Your phone seems to be in permanent diag mode. Dial ##upst# and put it in pda mode.
Sent from my DROID2 GLOBAL using Tapatalk
Making it more simple for you ##UPST# = ##8778#
then one menu will pop up, on that you will see two PDA and two Modem options
Select both PDA
then connect phone to PC via USB cable
