cavarun
HTC Droid Incredible - Need Help With Root (Gingerbread 2.3.4)
hi guys,
i am on Ginger Bread 2.3.4 stock rom on om incredible. (thanx parin for the link to the same)
my dinc is s-on,
i hv never rooted my phone before.
i hv checked with unrevoked forever it is not supporting dinc gb 2.3.4 for s-off.
i will be most delighted to learn the procedure to s-off my phone.
thanx in advance
:previous:
sir,
this will work only if the phone is already s-off
but my phone is s-on
so this method is not for me.......
thanx anyways......
dear varun.. you took it wrong.. kapil asked you to downgrade your inc to froyo & do s-off and then again update to GB.. your s-off will remain then..
thanx alok for clarification......
as i was reading on some forum that downgrade is not possible once updated to gb 2.3.4 (if the phone is s-on)
if any member with s-on has downgraded, plz advice.....
thanx
varun
i think this may be the solution......
hv downloaded all the files mentioned in the post..............
will post if sucessful or otherwise......
http://androidforums.com/incredible-all-things-root/427344-2-3-4-root-downgrade-s-off.html#post3308717
ps: this link is also posted in some other topic...........
I cant comment for Incredible 1. But I have downgraded Many Incredible 2's from 2.3.4 to 2.3.3.
