joshm
Data fix is to fix the loss of data that happens when you flash any custom ICS build on fascinate.
For data to work your evdo must be activated from reliance back end and then your handset should be provisioned for evdo services.
Its just not that simple.
Energized from The Fantastic Galaxy S3
Bro,.. I successfully installed ICS,.. YAHOOOO!!!!! Its awesome,.. ;)
Good for ya mate.
Have fun.
Sent from my Nexus 7 using Tapatalk 2
sure mate, thanks for your assistance,.. ;)
To all the users of samsung fascinate who bought the phone from Reliance and were stuck with stock setup because 1x/3g data didn't work on custom roms , I found a solution for you. I've been asking around many forums but could not get any answers. But djp952 from xda helped me out. Thanks to him, I'm now on the latest android version 4.2.1.
Pm me if anyone is interested . I'll be happy to help.
Edited by Maverick75
Mav wouldn't it be great to share it here for all.?
Great job mate...!!!:)
yes it ll be a great help for our Reliance Fascinate users.
Plz share it.
Sent from my Nexus 7 using Tapatalk HD
Sure I would. Am just waiting to login from a pc. I usually check out posts on rimweb on my phone itself.
Edit:
Hi Everyone!!
The following settings are applicable for All the people (if any) who have bought a Samsung Fascinate (SCH-I500) from Reliance and are currently stuck with stock rom setup (eclair or froyo). As you know, 1x/3g data did not work on Custom roms (either touchwiz or mtd based). DJP952 from XDA (geewiz Rom) has helped me out with the following procedure which will enable you to have the latest Rom of your choice.
Things you will need:
1) The Apns-conf.xml & cdma-carriers.xml file from your existing froyo or eclair rom
2) Yaffs explorer or similar app which allows you to edit your build.prop file
3) Custom Rom of your choice.
Procedure
1) Copy the apns-conf.xml file and cdma-carriers.xml file from the following path /system/etc using yaffs explorer app to your sd card
2) Follow the procedure given by the Rom developer to flash a new custom Rom (MTD or Touchwiz) and subsequently any gapps and other apps like yaffs explorer.
3) After you successfully boot your phone and make sure everything is working fine do the following to enable 1x/3g data on your phone
4) Switch to Airplane mode
5) Copy the apns-conf & cdma-carriers files to the same folder ie /system/etc of new rom. Make sure to set properties as rw-r--r-- for both files.
5) Next you will need to Modify the build.prop with these settings:
ro.cdma.home.operator.numeric=40400 (original no will be something like 310012 etc)
ro.cdma.home.operator.alpha=Reliance (is usually verizon)
net.cdma.pppd.user=user net ( is usually user[space]verizon)
net.cdma.pppd.password=password net
Remember that if you do not find any of these settings in build.prop file you can create new entry. Type just the settoings in BOLD . No extra spaces.
Thats it. Just reboot and your phone will now connect to 1x/3g network.
Cheers
  • Like 5
Updated the instructions with only necessary steps required. Figured out long ago but thought this thread was dead so dint post.
Hi Everyone!!
Procedure
Remember that if you do not find any of these settings in build.prop file you can create new entry. Type just the settings mentioned in BOLD . No extra spaces.
Cheers
hello
I have a samsung galaxy fascinate currently it is working on a 2.2 froyo .i wants to update ics or jb.
i rooted my fascinate through odin and superuser.now when for flashing rom from sd card i choose zip from sd card and it shows error 7 aborted.
kindly help me please guys.
thanks ..
are you using custom recoery ?
Yupp indeed, have you installed the red Cwm recovery, coz without custom recovery you can't flash anything.
The link is there in this thread at first page, flash it via Odin and then proceed.
Sent from my SCH-R950 using Tapatalk 2
i do all thing ,but at last it shows error 7 ebborted.
Sent from my XT901 using Tapatalk 2
Vahid bhai got sucess on rom update, but his ## codes are not working..
@Vahid
## codes are related with your rom ESPT, in most custom roms ## codes wont work. you need to use work arounds for same
yes hitesh bhai,now any proper solution for use code in custom roms??
DIAG mode only work in EH03.
Triggered from Transformer 300 using Tapatalk HD
try Samiota app it may work,
or use terminal commands to get diag mode
I have a sch-i500 Reliance with stock froyo 2.2 installed.
Please recommend me a good and stable ics or jb build to upgrade my phone.
Kindly give the instructions of using it if possible.
thank you
Just follow link posted by vahid. Its 2-3 post back
Sent from my Hydro
There's a forum dedicated to fassy on xda. You will find all details there. The latest is cm 11 ie kitkat. I'm running it since few days and is much better than any JB rom.
Sent from my SCH-I500 using Tapatalk
So you think its stable?????
Sent from my Hydro
U mean this one??
hmm,i flashed 4.2.2 rom but ## diag code is not working ,any proper solution?
i flashed this rom
http://forum.xda-developers.com/showthread.php?t=2238075
U use it on reliance right?
so does your data and network work fine?
Yes.it is good nd stable rom.
I used it.
Sent from my SPH-L900 using Tapatalk 2
