ashishbabu 1 Report post Posted March 10, 2005 How can I activate call divert in 3105. If any one have codes for nokia 3105 please post me. thanks in advance. Share this post Link to post Share on other sites
Mukul 0 Report post Posted March 16, 2005 The details are there in the Manual....It is very simple if you are still stuck then try *333. Share this post Link to post Share on other sites
umeshd 0 Report post Posted March 23, 2005 Hi there Ashish, Just bought 3105 too. And I use following codes for a long time - just checked and these work on 3105 as well. So you should not have any problems. *305 followed by number where you want the calls to get forwarded is what you are supposed to dial. For voice mail dial *3053600. To cancel all call diverts dial *308 If you need code for forward all calls, checkout RIM site - I don't use that usualy so don't remember. Hope this helps. Regards UD Share this post Link to post Share on other sites
