mfaiz2
Rooting Motorola Droid 2 / Droid 2 Global / Droid X/ Droid X 2 / Droid Pro
Here is the simple guide how to root Motorola Droid 2/Droid 2 global/Droid x/Droid X 2/Droid Pro
Download Latest Motorola drivers here.
Install the drivers.
Download attached zip file and unzip it in any folder.
Don't forget to connect your phone with usb debugging on and connect it in PC mode.
Click on motorola root tools.exe inside the folder you downloaded.
One window will open and now click on root my phone.
Your device will be found and from here onwards tool will do everything.
You just need to wait and watch. Don't Painic, It will reboot 3 times and don't disconnect the phone until it says your phone is rooted successfully.
Though this guide is safe to use but as precautionary warning you have to do it at your own risk.
Pm me if you face any difficulty.
Press Thanks if it helps :)
MotorolaRootTools_v1.07(1).zip
  • Like 6
Though I don't have those Moto phones to try, I love the simple-to-try rooting methods... Keep them flowing in our great forum... One suggestion, if possible, please provide the source also, so that we can get more ideas from the users' experience there say reg the precautions, possible mistakes, to check if it works for new/old version android as well, etc...
Thanks and +1 to you...
Edited by KanagaDeepan
Thanks for the tutorial! I hope this works. I will try it on my Motorola Droid Pro and hit back.
Faiz keep it up bro +1.
I hope it worker for you... :)
Thanks. It was easy to root the droid pro using this.
Hope you are enjoying your phone...
Thanks Mujeeb.
Nice Share. +1 Faiz Bhai.....keep posting the useful stuff. :)
Hi
I am trying to root my phone ie droid pro
mohd faiz the root method given by you gives me and error
SEARCHING FOR THE PHONE (connect it now if you haven't yet)... found!
Running exploit step 1 of 3 (setting up symlink)... done!
Rebooting your phone... done!
Running exploit step 2 of 3 (modifying local.prop)... done!
Running exploit step 3 of 3 (adding su, busybox, and superuser.apk)... FAIL!
ERROR: adb could not be granted root access via local.prop method
Try again from the start, but if the problem continues, check your version
of Gingerbread -- hopefully you don't have a version where this exploit
was fixed.
@kapil ji root method
http://dl.dropbox.com/u/66473210/motoerror.jpg
The error is in above image as I was unable to copy the text from command prompt
I also tried MotorolaOneClickRoot_psouza4 from http://www.mediafire.com/?g226n7as6cb1y6e it says that successfully rooted the phone
But I still get the error phone is not rooted when I am trying to edit the files.
Any help please.
I really need to root it to make net and sms work in it
thx kapil ji
I tried this in automatic mode and also downloaded motofail and other 2 method but the things are getting stucked up in step 7 for auto and other 2 modes ie Waiting for Device
Also
In Motofail Step 5 ie Waiting for Device
I have attached the screen shot for the same.
https://www.dropbox.com/sh/1sext324v2hgzzp/P8ramXJghg#f:clickoneerror.jpg
Any guidance kapil ji
Try SBFing (using RSD Lite) the phone again to latest version and than try rooting again.
Also make a note of your MIN since all programming would be lost once you SBF Droid 2 Global.
