rajanmehta
Reliance NetConnect+ Plans - My Best Plans - Usage based plans
Reliance seems to have introduced new plans for Reliance Netconnect+ termed My Best Plans.
Instead of a fixed amount and quota, you get charged on variable basis and then there is a Max Bill Limit Capped at Rs 950.
Prepaid Packs are also changed.
Official Webpage Link >> http://www.rcom.co.i...s_internet.html
Details in the image.
Plan summary (for both HSD and 3G):
Data Usage
Billed amounts (Rs)
Less than or equal to 500 MB
350
> 500 MB, upto 1000 MB
350 + 60p/MB for usage above 500 MB
>1000 MB, upto 6000 MB
650 +6p/MB for usage above 1000 MB
> 6000 MB (Speed throttled)
950
Plan codes
PRODUCT
REFERENCE_CODE
ABBREVIATION
HSD
51352
NCPLUSMYBESTPLAN_350
GSM/RTL
51353
3G_MYBESTPLAN_350
Business rules:
  1. The existing customers can to the My Best Plan (However, please avoid pro-active migrations and promotions to existing base for My Best Plan).
  2. This plan can be used to retain the churning customers
  3. The plan is available from tomorrow 21-Dec-2011.
  4. This plan is applicable on 3G and HSD dongle customers only.
  5. There will be no change in channel margin (Plan rental of Rs. 350 would apply).
Unlimited Plans (for both HSD and 3G):
In addition to introducing the My Best Plan, we have revised the HSD and 3G Unlimited plan rentals. The new plans are as follows:
Data usage at full speeds
HSD
3G Dongles
5 GB unlimited
750
750
10 GB unlimited
950
950
15 GB unlimited
1200
1200
HSD Plan abbr.
3G Plan abbr.
5 GB unlimited
NCPLUSSILVER
3G_5GBUnltd_750
10 GB unlimited
NCPLUSGOLD
3G_10GBUnltd_950
15 GB unlimited
NCPLUSPLTNM
3G_15GBUnltd_1200
All existing plans except My Best Plan and Unlimited plans will be discontinued for new customer acquisitions w.e.f. 31st Dec’11.
Hub marketing team may decide to add one circle specific plan which may be an existing plan like speed based or time based.
Prepaid Packs
We have also simplified the prepaid packs and made them more attractive.
Pack type
Data Usage
Validity (days)
HSD
3G dongles
MB Packs
1 GB
7
225
225
500 MB
30
350
351
1 GB
30
650
650
Unlimited
5 GB (3G) (Unlimited only for EVDO)
30
800
800
10 GB (3G) (Unlimited only for EVDO)
30
1000*
1002
15 GB (3G) (Unlimited only for EVDO)
30
1300
1300
Long validity
6 GB
90
1500
1500
18 GB
180
3000
3000
are these plans apllicable for omh phones too ?? if yes . i still did not get the plan i was waitinf for like 110 rs 30 days 250 mb like gsm 3g people get.
Yes we need good prepaid neconnect plan for CDMA........
Edited by parin
does this mean the rs. 100 for 30 days is also gone?
now i'll have to switch back to airtel - so stupid ...
even though we are not fully satisfied with the plans, but it is a great step towards a better future for cdma
i only need a 150-250 mb plan, or may be 100 mb will do, i only need internet for stay online 24/7 and live updates , i use offline navigations and other stuff but for 30 days, i hope to see such plans
Seems to be new changes in the RCDMA data plans. Still need cheaper plans for prepaid. Like 1GB - Rs 350/30days
Tata DOCOMO CDMA (Tata Indicom) has better plans when compared to reliance
Rs100 - 256 MB
Rs300 - 1GB
Rs500 - 2GB
Rs950 - 5GB
Rs1100-10GB
Rs1500-15GB
Source:http://cdma.tatadoco...dded-packs.aspx
post-47370-0-09015900-1325828023_thumb.j
Edited by aankush
at least airtel has 200 mb for rs. 100 monthly recharge - rcom does not have any smaller amount
i've heard MTS might be cheaper but where can we get the forms in chembur?
According the Rcom website, this new offer only for datacards. For mobile phones, browsing same as old 60p/minute. OMG :nerves:
My Best Plan is now sweeter. 250 Rs. with 1000 MB bundled usage
Prepaid Packs has also been made more attractive with higher allowance/lower cost.
Great increase in data allowance for long validity packs too.
@ Mobile Fan, pls share the details of your Sweet 250 plan... Is it applicable for CDMA... Is it postpaid or prepaid...
I would also like to know whether it is advisable to convert my 9.5 years postpaid CDMA connection to prepaid, after seeing the increased usage of data as well as voice within my same range postpaid bill...
Currently I am subscribed to below mentioned billing parameters---
> PPS 199 (where I get 15000 seconds free calling for a month, post which I have been charged 1.2 Paise per second)
> On Net 99 ( R to R Unlimited Local calling)
> SMS Pack of Rs.25 (for max possible SMS as per TRAI)
> Data plan of 247 which gives 1 GB EVDO per month
Pls suggest a good plan in postpaid for above charges with increased free usage or prepaid combination...
Sent from my Nexus S 4G using Tapatalk 2
My Best Plan details are available on Rcom.co.in
Sent from my XT800 using Tapatalk 2
But if want to use mobile for data then the new 94 rs. Plan might be suitable to u. It has 1 gb of free dara
For Netconnect+ FUP plans where the speed drops to 1X after consumption of data allowance, one can now buy NC+ Speed Booster Packs of 500MB and 1024MB for Rs 150 & Rs 200 respectively and the speed will get restored to HSD again.
Click HERE to view your "Do it Yourself Guide"
Happy Hours Free Browsing For Reliance Netconnect+ Prepaid Customers in South Circles of TN,CH,KL,KT and AP
