st_7
What is the Best Screen Protector & Case for HP Touchpad
Dear Rimwebians, Please suggest me a good Screen Protector as well as a good case for my HP TP.
Looking for Screen Protectors with the following qualities: 1)Good Quality, 2)Display should be clear after applying, no yellow effect or any that sort of, 3) anti-glare & anti finger print, and which doest not reduce the touch sensitivity. Budget max Rs.500/-, In my search I've found one from Amzer for IPad2 which can be used for HP TP, http://www.indiaplaz...012amz02-10.htm ,if any body used that pls share ur opinions, or else suggest any other u know with the above qualities I mentioned.
For the case I zeroed in on this http://www.amazon.co...m=APWOA8E6ZFGQF the only draw back of that is it blocks ambient light sensor of TP otherwise a good one or I'm thinking to buy official HP sleeves(not cases) which comes for around $13, again share ur opinions on them if u have used or suggest me a good case for TP
