prafulrc
HP Veer 4G - No Display But Phone Working
Dear Rimwebien,
i have hp veer 4g gsm unlocked ...
problem is hp veer dropped a week ago.
some color garbage shown and after that no display . sound ok , i can pick call with slider.
i doctored also . i tried three time riger on /off. no luck. i removed battery also.
please help me solve the no display problem of my veer 4g.
thank you in advance.
how much it costed you?...maybe you need to change front panel...
i costed me 7500 in sept .
best regards
prafull
dear rimwebiens,
from where i can order hp veer screen part. i have sns account.
regards
prafull
Buying a brand NEW phone at US $ 114 >> http://www.ebay.com/...#ht_4404wt_1031 may make more sense then replacing Touch Digitizer at US $ 90 >> http://www.repairhpp...eer-p-5710.html
Hi rajanmehta
As hp veer os was good has two drawback is no camera flash and small screen. want to upgrade pre 2 gsm any good deal below 10k.
regards
prafull
Not strictly within 10K, but still a good deal with the bundle >> http://www.ebay.com/...#ht_1986wt_1265
There is another one for effective US $ 20 less but somehow i don't find the seller inspires confidence and there is no bundle as in above >> http://www.ebay.com/...#ht_1357wt_1265
