shadaabsharik
YouTube not working on Samsung Galaxy S2
i have this Samsung S2 with android 2.3.6 (Gingerbread), everytime i try to play a VDO (with EVDO or WIFI) in its inbuilt youtube it does not play, not even with any of the browser, anyone can assist me in making things better for me ?
Have a Blessed evening
Try this
Which version of Youtube application is installed on S2 ?
kamal, it is 2.3.4
this is not OS issue
just follow the video
kamal, it is 2.3.4
Shadaab did you tried upgrading it to 2.3.6 ?
kamal, it is 2.3.4
ok, then i gotta get the MSL issue solved first.
dial ##data# go to edit enter your msl which must be 000000 if u have purchased from the forum go to others tab and change the R.T.S.P proxy addres and R.T.S.P port to 0.0.0.0 and 0 respectively and same to http proxy address and port your youtube will work like a charm with the data networks though your youtube will always work fine when you try connecting with wifi even without this settings.
Ok parin bhai has already given the solution didnt check the video before posting but i gues your msl should be 000000 try that
MSL to 000000 is not compulsory
but u need to know ur MSL
Thanks..now the youtube works like charm:D
Enjoy
I have to re-enter THE above settings everytime on my phone for Youtube to work on EVDO. Any solutions for this?
Sent from my MB855 using Tapatalk
No just one time
DIal ##DEBUG# 1000% Successfully Method
1. Install AnyCut from Market
2. Go to Korea MODE and Select India Mode
3. Open AnyCut and Create New Shotcuts to Activity names Proxy Settings
4. Open Proxy Settings Shortcut and Wipes every thing
5. Reload the EVDO Dump your Seller may have Provided
@ parin,
I mean, every time I use You Tube, I have to re-enter the settings. In short the settings are not being saved.
Edited by KumaarShah
