sklm
Making A Handset As Blank.
We all know that Reliance is seling blank Nokia sets which to be used
with HCC or GSK right? If a phone has a due of some thousands rupees
then if one can blank the set then the set can be used as new set like
Nokia's.
How to blank a set? I tried to set the M?? to 0s but after dialing *228
the sweet lady says "your phone had already been activated your phone
no. is 93XXXXXXXX. How is it possible. I also tried by erasing the E?? to 0 but after dialing to *228 the lady says "your phone could noy be activated". So how to blank a set like LG2030, Samnung N191 or Nokia 2280?
Nokia's.
28345[/snapback]
you see reliance changes only handset but not your a/c.
so your dues will remain.
Sorry, nothing to do with the dues will pay by installment. I want to know how to blank a handset not the a/c.
Reliance is not selling Blank sets of Nokia but sets which are Reliance Ready - which means the ESN of these handsets is registered with Reliance. When you use a HCC or a GSK a MIN is alloted to the mobile and is associated with the ESN.
When you dial *228 after setting MIN to 0s, the lady recognizes your ESN and says it has already been programmed, and when you set the ESN to 0s the Reliance servers obviously fail to recognize your set and do not activate it.
In simple words its not that easy to erase everything from handset and re-activate it. :o
