volstagg
Please suggest EVDO Handset for Tata Indicom
Hi guys I'm looking for a cdma handset for my tata indicom prepaid no.my main priority is that it should have evdo (upto 3.1 mbps), decent camera and a good user experience.
You can go in for Samsung Galaxy Ace Duos I589. It will set you back by Rs.13,500.
GALAXY POP CDMA or GALAXY ACE DUOS
Please visit http://omhworld.com/devices before buying any handset (particularly Samsung Ace Duos i589).
Samsung India is even not aware of all the providers of EVDO (CDMA 2000) services in India.
So, double check the compatibility/functionality at the sale-point itself before making a purchase.
Samsung is about to launch S2 Duos (CDMA+GSM) which is supposed to support EVDO.
I have Htc Hero which MEID is registered with TATA if you want tell me
Buy HTC incredible 2
according to omh world,the only android phone which works with indicom is galaxy pop cdma. but according to the samsung website, galaxy ace duos is also OMH.
-------> check under the features tab for OMH confirmation
Galaxy ace tested with evdo network from tata
Sent from my HuaweiU8300 using Tapatalk
i appreciate your offer shreesh,but htc hero seems to be a very old handset. i'm looking for something new..like android 2.3..but thanks for the offer..i appreciate it...
