Genius 817 Report post Posted May 31, 2012 My friend is using Fascinate since last 5-6 months with EVDO - yesterday he did Kill all task using Advanced task killer, after that the phone went down. he is on OEM rom - On outgoing call does not matures - Incoming not happening - upon calling his no - there is one ring and then it says user not reachable (although his phone never rings) - calling we get a sms that the user is in range again (VAS - nothing special, but putting this as the number comes phone range) - No sms - the battery is draining very very fast Tried Factory data reset nothing is working. Need your valuable opinion - thanks Share this post Link to post Share on other sites
rajanmehta 4,056 Report post Posted May 31, 2012 (edited) This is wholly unscientific but worked with fascinate when it suddenly went into airplane mode and will not come out of it no matter what... Pull the battery out, then micro SD Card, wait for 2-3 minutes, put micro SD, then battery and power on. If that does not work, then stock ROM can be ODINed. Edited May 31, 2012 by rajanmehta 1 Share this post Link to post Share on other sites
parin 857 Report post Posted May 31, 2012 ODIN : http://www.mediafire.com/?6ipsaf418ah8gr5 Atlas Pit 2.2 : http://www.mediafire.com/?19fo7ftwgz8tgr8 EH03 STOCK official verizon GB : http://www.imnuts.org/downloads/fascinate/odin/CI500_VZW_EH03_GB_CM.tar.md5 OR http://www.mediafire.com/?g4afpb8u522oj2y http://www.mediafire.com/?r4fi9gl59j832yl Video Guide: Instructions: 1. Install Samsung drivers on your computer. 2. Open Odin on your computer. (You may need to disable antivirus programs on your computer and/or phone for this to work properly.) 3. Power off your phone and remove the battery. 4. Plug the stock USB cord that came with your phone into a powered USB port on your computer (usually on the back of the CPU). 5. Press and hold the "volume down" button on your phone, and continue to hold it while plugging the USB cord into your phone. This will put your phone into download mode. You'll see a large yellow triangle on the screen of your phone. (Let go of the volume button at this point.) You will also see one of the small boxes in Odin turn yellow, as well as "Added" appearing in the message box. 6. Click the PDA button in Odin (NOT the PHONE button) and navigate to the ".tar" file you downloaded earlier. Click the PIT button & Select the Atlas PIT 7. Click START. When this process has finished, you'll be notified in Odin (succeeded 1 / failed 0) and your phone's screen will go blank. 8. Unplug your phone, re-insert the battery, and power on. At this point your phone should boot up with the desired changes. परींन दौलत 3 Share this post Link to post Share on other sites
Genius 817 Report post Posted May 31, 2012 Thanks i have asked him to do ODIN - BTW he is from Thane and first thing i asked was - it it affecting all thane RIM phones then don't worry it will get solved soon as some one must have already attended to it. i have asked this card trick also Share this post Link to post Share on other sites
