shreesh
HTC Incredible battery overheats and restarts
Hello all,
need help from all rockstars of rimweb!
As I'm using HTC DROID INCREDIBLE from last 2-3 weeks I am facing a problem of overheating of battery and the phone restarts.
But i dont use phone for too much time but still it gets overheat and restarts.
So, sometime I remove the battery and wait untill it gets cool.
When the battery heat exceeds the phone gets OFF and vibrates 2-3 times and gets off.
And when the battery gets cool I start my phone but same incident occurs after 15-20mins,
I also tried using different battery for my phone but still I am facing same problem.
Thanks in advance
and please help me to get remedy!!!!
Check if any app is causing it. Use an app like BetterBatteryStats to figure it out.
i am using juice defender but still sometime it causes but using juice defender the proportion of this problem is minimised
Yes and thanks will try this app and let you know.
This is the beginning of the problem I have been facing with my DInc. It's a motherboard problem and so far haven't found solution to it.
Gradually the reset frequency will increase and the time will come when DInc will keep on rebooting endless.
^^^ but earlier it was working properly
I think some of the app may causing harm to it
I also hope that should only be the case. If its the case I faced, then I am sorry friend, your DInc has less time left.
Experts in the forum may have answer to problem of motherboard.
Please try searching on verizon site for user's grievances related to heating and reboot loop issue.
It begins with heat causing problem and cold tending to solve it, but with time, even cooling fails to solve it and gradually DInc goes into coma. I'm so sad about losing mine :(
heating proportion is minimised and can use phone for long time.
I think this problem was caused by one of the app
thanks arun sir for great app!
Which app was causing the problem?
Angry Birds
After upgrading it to ICS i am not facing any such problems!
When I use 'Camera FV', htc D Inc2 is getting heated up.
you have to do some experiments to solve this problem!
Helllo,
I purchased one more droid incredible on 13/7/2012 and same overheating issue was faced by me. I tried to solve it using various apps such as Better Battery Stats (Thanks Arun Sir), Juice defender but still it was causing battery to overheat and reboot.
Then I changed its rom from stock to custom and custom to stock but still the condition was same.After searching on Google about this problem I changed its radio and after changing it the problem is fixed and I am enjoying my another dinc.
Special Thanks to Arun, Parin, Sumit Verma, Hitesh Hambarde, Hetal Patel (Sir) for their kindful support!!!!
Here is the link which helped to come out from this problem.
Thats good news. what Radio was there before and what the new radio you have updated to?? and is it Incredible 2? or just Incredible?
Its just droid incredible1 just changed the radio version.
U should aslo try to change radio version
