Satheeshkumar Ravichandran 0 Report post Posted June 16, 2012 Really i'm searching for OMH sim card over a year. Still i can't get one. I'm having Galaxy POP CDMA I bought Tata Docomo OMH sim.It is worked well with pop. But i can't able to activate data plans but Internet worked on Pay as you go plan. I asked about this to customer care,They are not support and some of them don't know about OMH sim. I tried to activate as said in this page.But failed. http://www.tatadocomo.com/mobile-internet.aspx I want to connect to internet on my POP. Tell me good OMH CDMA Provider , Internet Tariff and how to activate it? Because i can't able to see Tariff on internet of various OMH CDMA Provider. Why? Share this post Link to post Share on other sites
mail_abhiks 0 Report post Posted June 16, 2012 Use Rs 48-1.5 GB for 21 days or Rs 95-3 GB for 30 days on Tata CDMA. I am using the same on samsung Galaxy aces Duos.. Share this post Link to post Share on other sites
me_saket 73 Report post Posted June 17, 2012 Just make recharge of rs94n and u will get credited with 4.5gb data with 30 days validity Sent from my HuaweiU8300 using Tapatalk 1 Share this post Link to post Share on other sites
ashokb 11 Report post Posted June 17, 2012 It must be 1x right? Share this post Link to post Share on other sites
KAPILKDEV 68 Report post Posted June 17, 2012 Quote But i can't able to activate data plans but Internet worked on Pay as you go plan Friend, are you activated EVDO in your OMH sim? At the time of purchasing OMH sim, it is only 1x CDMA activated and data will get about 144 kbps speed. To get higher speeds like 3.1 Mbps, you should activate EVDO in addition to 1x in your sim. In most EVDO handsets two tower symbols with two different signal strength will be shown (same like dual sim handset) one tower symbol for 1x signal and other for EVDO signal. Showing EVDO signal symbol in your handset does not mean your sim is EVDO activated, handset will show EVDO symbol and signal strength in EVDO non activated sim also. If your sim is not activated with EVDO, contact your service provider's customer care or exclusive shop. Efforts and struggles to activate EVDO in sim are already discussed in our forum. I am using MTS OMH sim with EVDO activted in MTS Livewire (ZTE) handset, I got EVDO activated sim along with handset, so no experience of activation struggling. Share this post Link to post Share on other sites
aalok 442 Report post Posted June 17, 2012 ^ is EVDO activated MTS RUIM (came along with MTS Livewire) works with any other OMH EVDO enabled handset (Samsung Galaxy Pop or Samsung Metro TV, etc.) Share this post Link to post Share on other sites
KAPILKDEV 68 Report post Posted June 17, 2012 Sorry aalok. I am not tested it as I have no EVDO OMH handset. Share this post Link to post Share on other sites
KapilAgrawal 340 Report post Posted June 17, 2012 I am using TATA OMH with 1x @ Rs. 33/10 days with 1 GB. using mdn@omh.ttsl.in/password if I go to EVDO area, than I get charged 10p/10KB 1 Share this post Link to post Share on other sites
krishnendu halder 24 Report post Posted June 17, 2012 On 6/17/2012 at 1:31 AM, me_saket said: Just make recharge of rs94n and u will get credited with 4.5gb data with 30 days validity Sent from my HuaweiU8300 using Tapatalk how to get evdo activated in indicom?and what settings? No help in this page http://www.tatadocomo.com/mobile-internet.aspx#tata03 Share this post Link to post Share on other sites
mail_abhiks 0 Report post Posted June 18, 2012 Just buy a normal Tata CDMA OMH RUIM. Tata has restrted EVDO activation and it comes by default with new Tata CDMA OMH RUIM. Plus Rs 48-1.5 GB for 21 days and Rs 95-3 GB for 30 days on mobile works on EVDO. No separate data settings-choose OMH profile. Share this post Link to post Share on other sites
