HetalDP 947 Report post Posted June 26, 2012 After too much followup from the concerned team a new Universal Username and Password is approved for all Prepaid and Postpaid NetConnect or RWorld plans UserName = net Password = net If you are using Imported device please Always Reactivate EVDO to your new Device otherwise you will be billed for usage on your old device ! 16 Share this post Link to post Share on other sites
@Akash 23 Report post Posted June 26, 2012 Thank you very much.. Share this post Link to post Share on other sites
javed91214 67 Report post Posted June 26, 2012 Great Hetal Bhai, i am using MotoDrois Razr with OMH sim card ,help me to enter user name & password. Share this post Link to post Share on other sites
@Akash 23 Report post Posted June 26, 2012 ^^^ Nope its not free. But, you have universal settings for any handset. You dont have to feed username/password which were earlier based on MEID or MDN. 1 Share this post Link to post Share on other sites
vishalsheth 19 Report post Posted June 26, 2012 so it's only replacing MEId or MDN. Everything else would be the same as per the plan. Share this post Link to post Share on other sites
aalok 442 Report post Posted June 26, 2012 one more feather in the cap... Share this post Link to post Share on other sites
rajanmehta 4,056 Report post Posted June 26, 2012 Great! Thanks HP! Appreciate all the efforts for getting this through. Must have been long and tiring. Will the same common username/password work for EVDO HSD Data also in addition to 1X? Share this post Link to post Share on other sites
ami1 237 Report post Posted June 26, 2012 (edited) ^ ...and will the earlier meid based username/password for EVDO keep working OR do we have to change it to net/net now ? Edited June 26, 2012 by ami1 Share this post Link to post Share on other sites
hiteshkkk1 327 Report post Posted June 26, 2012 (edited) From what I understand & my talks with HP, there are 2 parameters. 1. EVDO Parameters - Required to latch / authenticate to EVDO signals. HDR Username & HDR Password are EVDO parameters. 2. Netconnect parameters - Required to start DATA (1x or EVDO). Earlier we used to login either by using MDN as username & password or by RWORLD username & password. These parameters are needed to access data & also billing is based on this. Now, based on above facts, I conclude as below, (Pls correct me if I am going wrong) a. Even if 1 is incorrect & 2 is correct 1x will work & evdo will not work. b. If 1 is correct & 2 is incorrect 1x or evdo both will not work. c. Suppose u r using mdn 93xxx with meid : ABC & activated evdo on this meid & using internet with username / password as net, then when u change the handset, evdo is still active on old rsn-mdn pair i.e 93xxx : ABC. So, if your handset buyer uses evdo on ur handset with rsn ABC & username n password as net, then u will be billed since meid ABC is linked to your no. 93xxx. So, whenever u change handset, immediately re-activate evdo on new meid so old meid-mdn pair would be cancelled n new meid-mdn pair would be active. Hope my explanation & conclusion is right & helps the community... Edited June 26, 2012 by hiteshkkk1 1 Share this post Link to post Share on other sites
HetalDP 947 Report post Posted June 26, 2012 its only PPP UID and Password to make IP Connecttion it dont have to do anything for EVDO (EVDO UID and Password will be required and it will be available in dump only format fori mported phones) for Reliance phone dont worry for EVDO UID and other stuff just use net net in PC 1 Share this post Link to post Share on other sites
Jasmin Shah 16 Report post Posted June 26, 2012 dear hetalbhai its a great work done by you and team i dont know if this is the right place to post this request i am using a fascinate with 1x data can anyone help in activating the evdo does evdo also has pay as you use kind of plans jasmin shah Share this post Link to post Share on other sites
KapilAgrawal 340 Report post Posted June 26, 2012 in short - No need for any programming if you want to change number on your handset. Since HDR tunnel authentication UID & Password are MEID based & EVDO/1X authentication UID & Password are standard for all (irrespective of MDN). Hence no need for re-programming. Before it was required to program handset everytime in case of MDN change since MDN/MDN were used as EVDO/1X authentication UID/Password. Share this post Link to post Share on other sites
nitink 279 Report post Posted June 26, 2012 good news Share this post Link to post Share on other sites
shreesh 406 Report post Posted June 26, 2012 Hetal Sir mods please pin this topic Share this post Link to post Share on other sites
digitalnirvana 646 Report post Posted June 26, 2012 Thanks Hetal bhai. One question, earlier in PPP tab in CW we used to give MDN/MDN - do we need to change that to net/net even if not changing handset? Share this post Link to post Share on other sites
hiteshkkk1 327 Report post Posted June 26, 2012 ^^ as of now, mdn/mdn or net/net both will work & behave same wrt to Billing. net/net is introduced so as to avoid hassles of changing username/password for new no.every time handset is changed. If u are not going to give ur handset to anyone, u can keep using evdo with existing mdn/mdn settings too. It won't stop working... Sent from my SPH-D710 using Tapatalk 2 1 Share this post Link to post Share on other sites
aalok 442 Report post Posted June 26, 2012 On 6/26/2012 at 10:29 AM, hiteshkkk1 said: From what I understand & my talks with HP, there are 2 parameters. 1. EVDO Parameters - Required to latch / authenticate to EVDO signals. HDR Username & HDR Password are EVDO parameters. 2. Netconnect parameters - Required to start DATA (1x or EVDO). Earlier we used to login either by using MDN as username & password or by RWORLD username & password. These parameters are needed to access data & also billing is based on this. Now, based on above facts, I conclude as below, (Pls correct me if I am going wrong) a. Even if 1 is incorrect & 2 is correct 1x will work & evdo will not work. b. If 1 is correct & 2 is incorrect 1x or evdo both will not work. c. Suppose u r using mdn 93xxx with meid : ABC & activated evdo on this meid & using internet with username / password as net, then when u change the handset, evdo is still active on old rsn-mdn pair i.e 93xxx : ABC. So, if your handset buyer uses evdo on ur handset with rsn ABC & username n password as net, then u will be billed since meid ABC is linked to your no. 93xxx. So, whenever u change handset, immediately re-activate evdo on new meid so old meid-mdn pair would be cancelled n new meid-mdn pair would be active. Hope my explanation & conclusion is right & helps the community... one more clarification required : EVDO is activated always on MEID/ESN (RSN) and MDN pair. once EVDO is active from backend, one needs to enter HDR Username & Password (varies from device to device) or nv dump for HDR Username & Password. what i understand from the first post is Universal Username "net" and Password "net" is to be used for activating Data Connection (1x), rather than MDN as username & password for netconnect plan or "omh****@***.relianceinfo.com / S**************D" for Rworld plan. HDR Username & Password is still required to enable EVDO on Imported handsets. Please correct me if i am wrong.. Share this post Link to post Share on other sites
KapilAgrawal 340 Report post Posted June 26, 2012 On 6/26/2012 at 6:53 PM, aalok said: HDR Username & Password is still required to enable EVDO on Imported handsets. Please correct me if i am wrong.. You are 100% right. HDR username & password are must to enable EVDO. without them only 1x will work. Share this post Link to post Share on other sites
digitalnirvana 646 Report post Posted June 27, 2012 On 6/26/2012 at 6:24 PM, hiteshkkk1 said: ^^ as of now, mdn/mdn or net/net both will work & behave same wrt to Billing. net/net is introduced so as to avoid hassles of changing username/password for new no.every time handset is changed.If u are not going to give ur handset to anyone, u can keep using evdo with existing mdn/mdn settings too. It won't stop working... Sent from my SPH-D710 using Tapatalk 2 Thanks, now one more question - for netconnect using dongle on PC, we dial #777 with some MDN as UID/PWD. Will that need to be changed to net/net? I am talking about data card. Share this post Link to post Share on other sites
hiteshkkk1 327 Report post Posted June 27, 2012 On 6/26/2012 at 6:53 PM, aalok said: On 6/26/2012 at 10:29 AM, hiteshkkk1 said: From what I understand & my talks with HP, there are 2 parameters. 1. EVDO Parameters - Required to latch / authenticate to EVDO signals. HDR Username & HDR Password are EVDO parameters. 2. Netconnect parameters - Required to start DATA (1x or EVDO). Earlier we used to login either by using MDN as username & password or by RWORLD username & password. These parameters are needed to access data & also billing is based on this. Now, based on above facts, I conclude as below, (Pls correct me if I am going wrong) a. Even if 1 is incorrect & 2 is correct 1x will work & evdo will not work. b. If 1 is correct & 2 is incorrect 1x or evdo both will not work. c. Suppose u r using mdn 93xxx with meid : ABC & activated evdo on this meid & using internet with username / password as net, then when u change the handset, evdo is still active on old rsn-mdn pair i.e 93xxx : ABC. So, if your handset buyer uses evdo on ur handset with rsn ABC & username n password as net, then u will be billed since meid ABC is linked to your no. 93xxx. So, whenever u change handset, immediately re-activate evdo on new meid so old meid-mdn pair would be cancelled n new meid-mdn pair would be active. Hope my explanation & conclusion is right & helps the community... one more clarification required : EVDO is activated always on MEID/ESN (RSN) and MDN pair. once EVDO is active from backend, one needs to enter HDR Username & Password (varies from device to device) or nv dump for HDR Username & Password. what i understand from the first post is Universal Username "net" and Password "net" is to be used for activating Data Connection (1x), rather than MDN as username & password for netconnect plan or "omh****@***.relianceinfo.com / S**************D" for Rworld plan. HDR Username & Password is still required to enable EVDO on Imported handsets. Please correct me if i am wrong.. Exactly right... Sent from my SPH-D710 using Tapatalk 2 1 Share this post Link to post Share on other sites
Genius 817 Report post Posted June 27, 2012 HP you are a Champion and a great entrepreneur - hats off to for your future vision Share this post Link to post Share on other sites
aalok 442 Report post Posted June 27, 2012 On 6/27/2012 at 12:34 AM, digitalnirvana said: Thanks, now one more question - for netconnect using dongle on PC, we dial #777 with some MDN as UID/PWD. Will that need to be changed to net/net? I am talking about data card. you can use any.. either MDN or net as username & password.. Share this post Link to post Share on other sites
digitalnirvana 646 Report post Posted July 1, 2012 On 6/27/2012 at 7:52 AM, aalok said: On 6/27/2012 at 12:34 AM, digitalnirvana said: Thanks, now one more question - for netconnect using dongle on PC, we dial #777 with some MDN as UID/PWD. Will that need to be changed to net/net? I am talking about data card. you can use any.. either MDN or net as username & password.. Thanks. Share this post Link to post Share on other sites
dr.faramroze 703 Report post Posted August 21, 2012 All is well because of RIMweb, if this information is not here it is nowhere. It's the special dedication thats there in this forum. Sent from my HTC Desire HD using Tapatalk 2 Share this post Link to post Share on other sites
bij78 0 Report post Posted September 6, 2012 Can we use 1GB given by RC 94 on our Reliance CDMA no. using unlocked mts dongle & using the NET/NET as user name & password. Share this post Link to post Share on other sites
