rppatil
Palm Pixi - Power Button and Restart Issue
Hello gurus,
I am using Palm Pixi plus( From Saddik Bhai) for last one year, running smooth.
But recently it is giving me some problem, It does not recognize Power Button pressing , and after long time it directly shows " Aeroplane/Power/cancel" options.
If tried multiple times , these button presses will result in sudden restart or on/off screen multiple times.
First I thought it is Power button issue, but I tried removing battery then phone worked perfectly for some time.
After some google search , I got somewhere forum that this issue might be due to Full Memory.
I noticed that , I had only 100 mb free in 8gb. So erased usb drive. Still issue is not fixed
I think "WebOs" is corrupt.
Few questions to Gurus here ,
i) Will WebOS doctor will affect Programming of phone(prl and all)?
Please help me to solve issue.
Go ahead with web OS doctor update... Also note you would need to bypass activation after Web OS update. Its fairly easy process n should solve your problem...
it won't mess with your nam /.prl / data settings.
