rahujas
Nexus S4G Radio Not Turning On
Gurus please help me.
I have a Nexus s4g with ICS 4.0.4 on it.
The problem is its radio is off and i am unable to find any solution to turn on the radio.
I tried flashing the stock rom using odin which was done successfully but the problem is still there.
On checking the status in phone settings, its showing the MEID as "unknown".
I also tried turning on the radio using secret code: #*#*4636*#*# but its not turning on.
Also i am unable to put the phone in diag mode using the 8778 code.
Its not getting detected by computer in diag mode whereas in normal mode it is detected as nexus and disk drive is also working.
Guys please help me to get this phone working.
Hope to hear from the technical gurus soon.
Deepak Rahuja
9312270605
Go here and put the phone to stock unrooted state. ( you have to flash the stock 2.3 factory image)
http://forums.acsyndicate.net/showthread.php?1824-ACS-HOW-TO-Root-Unroot-Flash-Roms-Kernels-Themes-and-CWM!-(17-videos)-12-16-11
Then try to turn on the radio.
Have a look at this link
:previous:
The above is related to GSM nexus S whereas mine is CDMA Nexus S4g.
Anyways, thanks for the effort.
http://forums.acsynd...ideos)-12-16-11
Tried this but of no use.
Still the same?
Please help further.
Check this and help if someone can.
http://forum.gsmhosting.com/vbb/f665/need-help-sph-d720-1475774/
