n_iceman 97 Report post Posted August 3, 2012 (edited) What takes more battery in Android CDMA devices? 1x or EVDO or Wifi I mean which mode is recommended to save battery assuming speed/cost is not a concern? Also assuming data consumption (in MB) is same. For example: If a device runs for 12 hours on Wifi mode till the battery drains completely, how many hours will it run on 1x and on EVDO Edited August 3, 2012 by n_iceman Share this post Link to post Share on other sites
Arun 795 Report post Posted August 3, 2012 Wifi would take up less battery than 1x/EVDO. If you do have WiFi access then use that. 2 Share this post Link to post Share on other sites
n_iceman 97 Report post Posted August 3, 2012 ^^Thanks Would wifi take 40% less battery than 1x/EVDO? What do you reckon? Share this post Link to post Share on other sites
