supernova 47 Report post Posted August 12, 2012 HAving problem in incoming display name of caller in two of my iphone 1. iphone 4 cdma : If the number is stored as +91 it will display name otherwise not whthere it is stored starting from 0 or straight without o or +91. 2. iphone 4 cdma with evdo : it display caller name only if the incoming call matches exactly as the entry is stored . for eg if display comes 09314****** then it will display only if the name is stored with 09314****** and it wont display if its stored as 9314****** or +919314****** I am facing great difficulty because of this . Most of the times don't get to know who the callers are . Share this post Link to post Share on other sites
Genius 817 Report post Posted August 12, 2012 ^^^^ Amit that's always a problem I have suggested some of my friends with this to store contact in +91 and 0xxx format both so call and SMS both get number Me too didn't find any solution to this Share this post Link to post Share on other sites
supernova 47 Report post Posted August 12, 2012 Any idea of some app I can try Sent from my iPhone Share this post Link to post Share on other sites
Genius 817 Report post Posted August 12, 2012 Their are some prefixer app but none for reliance some for other non Indian carrier that cannot be edited. 2 number are your best option in same name - edit it google - sync it To edit in phone use contact tool it has lovely editing capability and fixes in one go. 1 Share this post Link to post Share on other sites
supernova 47 Report post Posted August 13, 2012 Is contact tool dime app ? Can u Sent from my iPhone Is contact tool some app ? Can u throw more light how to fix in one go Sent from my iPhone Share this post Link to post Share on other sites
gauravjc 47 Report post Posted August 13, 2012 Contacts tool u can find in installous !!! Share this post Link to post Share on other sites
supernova 47 Report post Posted August 13, 2012 With the combination of contact tool and smart merge now all my contacts have been saved with numbers starting with +91 n 0 in same. Sent from my iPhone Share this post Link to post Share on other sites
KapilAgrawal 340 Report post Posted August 13, 2012 So so so many issues.. still iPhone sells.. 1 Share this post Link to post Share on other sites
supernova 47 Report post Posted August 13, 2012 Yeah. Even I am not able to link my contacts with Facebook. It was so easy on blackberry. Sent from my iPhone Share this post Link to post Share on other sites
supernova 47 Report post Posted September 24, 2012 I forgot how made two entries of same no with 0 and 91 in a contact in one go thru some app. Anybody any idea Share this post Link to post Share on other sites
pankaj.sea 4 Report post Posted December 27, 2013 Hi guys, Today I have updated my iPhone 4 to iOS 7.0.4 and what I found is the Reliance network (Call, SMS & Data) all are working fine though I haven't jailbreaked it yet or haven't done the programming using iDFS again. Previously it was running on iOS 6.1. So anyways, the problem I am facing is my iPhone is unable to display the incoming caller's contact from the saved contacts. For example if someone's number is saved as "Mr. X" "09331234567" when s/he is calling his/her name is not displayed as the number shown on phone is in this format 09331-234567; so I guess the issue is happening due to the hyphen inside the phone number. How can I turn that hyphen thing off or what's the way to fix this issue? Please help... Share this post Link to post Share on other sites
SmartSamrat 109 Report post Posted December 27, 2013 may be needs to edit carrier bundle after jailbreaking ios 7...!!! Share this post Link to post Share on other sites
SmartSamrat 109 Report post Posted January 6, 2014 Any solution on it??? I have same problem in iphone 4s gevey unlocked version Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
