StaticElectricity
No Data On The Samsung Galaxy Nexus S 4G
I have been unsuccessfully trying to activate data on my nexus s 4g. The phone works fine on the reliance network in all other respects.
My voice calls and sms work fine.
I have the username and password for the data access and i also put them on the phone via QPST. But still no data.
Can someone tell me what I am doing wrong ?
Ask for the NV item dump from your seller and write it using free utility from CDMA wksp
Is it Simple IP or Mobile IP on M.IP tab?
And on PPP UM tab, you have to put your Net user/pass(not the evdo).
Edited by phonegeek
I am no longer in contact with my seller. :-( Any other alternatives ?
Simple IP in the M.IP tab.
What do you mean by NET user/paas? Where do i get those ??
Put net/net which is default. Do opt for some data plan. You can search and find details on our forum.
Who was the seller?
Its settings totally wrong.
PM me the MEID.
Yep, I am subscribed to a data plan and I have got it confirmed from reliance CC. I am being billed for it but no data consumption.
PM me the MEID.
Have PM'd you. Please check and revert.
Already Replied. Waiting for your response.
WOW! Kapilji that was super quick. Im enthralled.
EVDO active on my nexus s!
1.5 mbps! Thank you all :D
Is it only the NV dump which can improve the network reception?
I bought this Nexus S 4G for my sister and now after almost 4 months she is telling me that reception on this mobile is not good. Wifi or Mobile network, either of them is not not satisfactory.
Any suggestion on this?
NV dump can only give u evdo
It won't help in increasing signal quality.
NV dump wont touch wifi!
Try changing radio if possible
Sent from my HERO200
Thanks for reply Hitesh bhai, can you please suggest any stable radio for my Nexus.
I have not used nexus S much
so cant say perticuler radio is good or bad etc.
you can try radio listed on this page http://forum.xda-developers.com/showthread.php?t=1077168
flash and test your self.
Also be-sure that you have saved your MIN number before doing anything.
thanks
Edited by ::Hitesh::
I also have the nexus 4G but i can only use the net at 1X Though i get the 3G INDICATION in the notification bar... I am also in no contact with the seller who programmed this handset....
Plz rimweb team do help me....
HAve you activated evdo on your mdn, send sms for HSD.
details here http://www.rimweb.in/forums/topic/36314-reliance-cdma-evdo-activation-via-sms/
if it says evdo already activated then try to get dump from seller, or we can help u in it.
PME UR MEID, NAME AND MOBILE NO.
I will check.
Sent from my VS950 4G using Tapatalk 2
