ramtech
TV Tuner card remote problem
Dear friends,
I am using Umax TV tuner card model 5821 for 1 and half year.
Now remote is not working properly.There is no problem in IC or internal circuit. I need to press the buttons hard to make it work.
I think buttons life is over. Otherwise remote is ok
I could not get new remote with service centre , they dont have stock now , will take month time.
I tried in local market which are available for Rs.100.but PIP is not working in any of the remotes.
Can any one help me how to make the remote work.
Or any one having new remote for selling .This post should have come in buyers post , but i am also seeking technical help so posted here.sorry mods
If you are residing in Mumbai you will get it at Lamington road, Bangalore in SP road and elsewhere I don't know. Lastly you can get conductive ink, open up the remote, apply it on the point not easily pressable. Conductive ink costs Rs 50 and more.
Sent from my HTC Desire HD using Tapatalk 2
:previous:
from where can we get the Conductive ink ???
Where can I get conductive ink in hyderabad.How should it be applied.Please help
Apply on the inner button keypad rubber tips, apply very little. This remedy is only successful if overall remote control unit is working normal.
Try replacing battery
Sent from my HuaweiU8300 using Tapatalk
You can also consider buying a universal remote....
Sent from my ADR6300 using Tapatalk 2
conductive ink pens are available on ebay for above Rs.2000
Conductive ink- could not locate availability.
Did any one have more info
Edited by ramtech
parallelly speaking with UMAX service centre guy(Neoteric informatics) for nearly one month. Made him to procure on new spare remote from Umax and and picked from their centre on friday .Costed Rs.150
Thanks for everyones support on forum
