mickeyforu
Dell XCD35 Going into Bootloop after flashing with Stock ROM
I tried to restore my Dell XCD35 Aka ZTE Blade with Dell Stock ROM but after that it went to Bootloop and I am not able to Get it into Clockwork recovery mode also. The only thing I am able to do it get an FTM Logo when I press Power + Volume Down Key.
Please let me know what should I do. Mine is a Gen 2 model
Thanks in advance
Mickey
I think u have lost ur root!!!
So what Should I do now?
Is there any way I can get the phone working ? Its not under warrenty
try clearing data to factory in any recovery stock or cw and see if it starts
Get 2.3.5 firmware update. It will be in zip format, extract it and you will see the bin file. Put the bin file on the root (no folder) of your sd card. Switch off your handset. Power on with power+volup+menukey together and it will update automatically. Let it boot for two mins and you have it working.
Sent from my HTC Desire HD using Tapatalk 2
Thanks a lot For help. Will try the options and hope to get it working.
Just one question to Dr Faramroze Sir. Where will i get the 2.3.5 firmware upgrade for dell xcd35?
Also K Shah sir After phone went to bootloop i accidently pressed power + volume down so i think i lost clockwork also :(
not sure but Flash TPT !
Edited by shreesh.pvg
Please search a little. 2.3.5 is available for download. Follow the process given by me above. Root will be lost because of flashing stock (DellXcd) Zte blade firmware. Recovery will also go. So after successful firmware flash, re-root and recovery and flash you own custom Rom.
Edited by dr.faramroze
I hope u would have already removed battery and tried...
Could u also try this once if it helps...
http://www.modaco.co...ra-via-windows/
Thanks a lot Theking The above method worked and now Dell XCD is Up and Running :)
Dr Sir Dont know why but I was not able to get the installation started even after putting the 2.3.5 image file in SD card :(
Anytime buddy....just try and update if u r not on the latest stock..
