Genius 817 Report post Posted September 2, 2012 Hey... Good news.I also had the problem of no radio in my nexus s4g.. Reading through this, i flashed stock ics rom using ODIN along with EFS clear option checked and VOILA... the radio is all OK after flashing. Cool. I love this forum. Mine main problem is Odin is not connecting - I am about to try flash boot method Sent from my iPad using Tapatalk HD Share this post Link to post Share on other sites
digitalnirvana 646 Report post Posted September 2, 2012 All the best doc! Share this post Link to post Share on other sites
shadow 119 Report post Posted September 2, 2012 i dont if it works , remove the battery and with out putting it back , go to download mode and see if odin detects it just a wild idea, try it and please tell me what was the result Share this post Link to post Share on other sites
Genius 817 Report post Posted September 2, 2012 is fastboot working? ...if it is ..then flash the ROM again via fastboot and install the radio again! ...have fun http://forums.androi...ion-method.html tried this method - it did flashed but failed to start radio tried twice Wanted to know that if there is some conflicts in MIN / MDN / MEID / ESN - the radio shuts down is this the possibility that i have missed some parameter in programing in this case any way to connect to PC and check via Fastboot as COM port is not working Share this post Link to post Share on other sites
ami1 237 Report post Posted September 3, 2012 (edited) If you want to reset the MEID/ESN to factory values then there's a linux cmd in android shell to do that unconditionally. Only if you haven't changed either of these values. Will search and post. Don't know if you are able to get an ADB shell on your nexus though ? If you can get it to bootloader mode then you can push the kernel from pc and it boots (i think its the same as fastboot) If even fastboot is not working then you can push a linux kernel for nexus to boot it to linux and then chroot to the android file system. But this requires you to first copy a big file to the nexus. Can that be done ? ie. can you mount the storage in bootloader /recovery mode ? BTW, ^ Is that Taylor Swift ? very distracting ..... Am scrolling up and down this post to keep seeing the pics you post. How do you find them ? Edited September 3, 2012 by ami1 Share this post Link to post Share on other sites
Genius 817 Report post Posted September 3, 2012 Don't know if you are able to get an ADB shell on your nexus though ? .................................................................... can you mount the storage in bootloader /recovery mode ? Let me know how it can be bone if its a small procidure - i am not very comfortable with CMD and dont know any LuniX at all BTW, ^ Is that Taylor Swift ? very distracting ..... Am scrolling up and down this post to keep seeing the pics you post. How do you find them ? Ya its TS and this is another pic from same shoot-out to add to your distraction - you know what save it for later - Share this post Link to post Share on other sites
ammar.cma 22 Report post Posted September 3, 2012 @ Genius Do u have fastboot drivers installed?! Share this post Link to post Share on other sites
ammar.cma 22 Report post Posted September 3, 2012 http://dottech.org/tipsntricks/21534/how-to-install-adb-and-fastboot-on-your-windows-computer-for-use-with-your-android-phone/ ^^ above link for getting adb and fastboot working on ur windows pc http://dottech.org/downloads/google-adb-drivers.zip ^^ adb drivers ( fastboot drivers for nexus s 4g) Share this post Link to post Share on other sites
ammar.cma 22 Report post Posted September 3, 2012 (edited) http://forum.xda-dev...63&d=1334200653 Radio.img for ICS 4.0.4 ( extracted from latest IMM76D) Rename to radio.img Flash in fastboot using... "fastboot flash radio radio.img" ( write radio 2 times ) ( without commas) *If your having problems after the radio flash......go to dialer: Type in *#*#72786#*#*, put your msl in, and let it re-provision *Make sure the radio.img you are flashing is in your \android\tools Edited September 3, 2012 by ammar52 Share this post Link to post Share on other sites
Vinod Nayak 443 Report post Posted September 3, 2012 That should work. Radio.img is same modem.bin Sent from my SPH-L710 using Tapatalk 2 Share this post Link to post Share on other sites
Genius 817 Report post Posted September 5, 2012 Finally - y'day it got connected and Radio started What went wrong in the set in first place I had copied the NAM programing from Moto Maxx and then written to Nexus 4G as per discussion with Kalpak Sir - there are many non relevant fields in MAxx moto - to when there is a conflict in NAM parameters the Radio turns Off What i tried Tried Odin in set turned on - Failed because it was not connecting to com port since radio was off Tried Update by keeping Files in SD card and doin in Fast boot mode Tried Fast boot Updating and flashing radio Where i was going wrong I always complained that its not connecting in Download mode - many friends have mentioned it that tnere is no reason it should, i was putting in DL mode by Vol up + down and very long holding Power Infact its Up + down and Power for just 2-3 sec - when i did this bingo i went in DL mode then ODIN in DL mode worked and since i had messed up NAM i had checked: Phone EFS clear (thanks to Kalpak sir) this clears all NAM to factory Thank you Section phonegeek for link for files Vinod Nayak for pointing and repointing and again repointing that i am doing wrong DL mode digitalnirvana For Staying there and boosting me plus international repair source rajanmehta for finding and sending required files and - supporting me offline too kshah for clearing phone NAm and Explaining me Hemdall and PIT http://www.glassechidna.com.au/ dkaile for keeping and alternate ready ammar52 for reminding ans rereminding me of Odin in DL mode ami1 out great lunix geek - with hard to understand ideas AND whome I forgot to mention - a big thanks Lesson to LEARN THERE is always lot to learn solution can be very simple always ask 3 Share this post Link to post Share on other sites
Vinod Nayak 443 Report post Posted September 6, 2012 I'm glad I could help. The same problem I faced when I unknowingly flashed GALAXY SIII nam on my epic. Did exactly what you mentioned. Sent from my SPH-L710 using Tapatalk 2 1 Share this post Link to post Share on other sites
ammar.cma 22 Report post Posted September 6, 2012 Glad you could make it work ! :) Share this post Link to post Share on other sites
