dr.faramroze
Tutorial: How to root and install CWM recovery on Samsung Ace Plus S7500
As per Tushar Gupta's request, I present the following guides to root and install recoveries on Samsung Galaxy Ace Plus S7500
Tutorial No.1
As always, warranty is void if you root your phone. No one is responsible if the user bricks the phone, someone shouts, internet package gets over, if you did'nt get night sleep. Flashing and DIY on your smartphones does'nt work on assumption so please follow the steps properly. I do not take any credits accept linking information here. All credits to XDA developers forum and the source developers.
1. Your battery should be atleast 80% charged before rooting process.
2. Your handset should be detected properly via KIES (if not already installed).
3. Extract Odin and put them on the desktop
4. Switch off and restart the handset by Power+Vol DWN+Home continously till the Samsung logo remains.
5. Connect your phone via USB cable.
6. Open Odin Click on PDA tab and select the recovery image for flashing
7. Hit start to initiate the process
8. Recovery will be installed on the phone now.
9. Switch off and again switch on with the above button combination to get into the recovery mode.
10. Extract the rooting files on desktop
11. Connect the phone via USB.
12. Double click the runme.bat file and rooting will start
13. Reboot from recovery mode.
14. Samsung Galaxy Ace Plus smartphone is now rooted.
Odin3-v1.85_3 http://www.mediafire.com/?9c5lah2rmxyptrc
Rootme.zip http://forum.xda-developers.com/attachment.php?attachmentid=1032490&d=1335783005
CWM recovery image http://www.4shared.com/file/MfJmh2bn/clockworkmod-5028tar.html
