dr.faramroze
Tutorial: [Android]: Setting up 1x/EvDo on RUIM handsets by Root Explorer
Good Job...+1 :)
Will it work with all the android phones or only with MTS MTAG 3.1, and also for all versions of android, (GB, ICD, JB)
Great work
Will come handy someday for sure.
Good Job...+1 :)
Thank you and @ krishna, it will work on most android phones because ril tweaks are there for all builds. Platform tweaks don't change.
Good one +1 for you
Sent from my ADR6300 using Tapatalk 2
Great job...
Good job done. Will test and let you know the result.
Sent from my DROIDX using Tapatalk 2
Great going..
successfully got 1x/EVDO (Reliance) configured on MTS MTag 3.1 after unlocking without rooting.
Voice/Text worked fine with all CDMA Operators available in India (except Virgin, but after all its Docomo CDMA :P) after unlock, but failed to get data..
Hotspot works great with Reliance too..
will test DATA with BSNL CDMA / Tata Docomo CDMA some other time.. :)
Dear aalok,
Purchased unlocked Mtag 3.1 today .
working voice with Reliance
Data working with MTS
Its has dafault MTS APN settings
New APN setting for rcdma can be added and save option is available.
Can you please provide APN settings and guide me how to add reliance APN with the settings
Thanks in advance
Edited by ramtech
^ please write all the parameters of MTS as it is on a piece of paper. Then create a new APN of Reliance and put all the parameters in their respective fields except username and password i.e. net/net. Save and reboot..
make sure not to change any string, specifically, MCC/MNC.
enjoy reliance on MTag 3.1 :)
Yes aalokji
before you replied
I Tried below
I replaced APN with #777
USer id with MDN
Password with MDN
Prompt password with #777
in NEW APN and saved
IT WORKED and EVDO already activated now worked great , can view youtube videos
Actually I remembered few years back In spice dual sim handset i input settings similarly and it worked
I dont know weather the phone is rooted or not
looking at your above post mentioned that Data working without rooting I tried above
When I bought this Mtag today for Rs.3200.Though it was unlocked data was not working and seller told that data will not work.
Then I called Dr.Faramroze and he gave confidence that data can be made to work with rooting which is not difficult and he even offered me to guide in the evening and suggested me to go through aalok ji's tutorial also once.
with great trust in our RIMweb forum support I bought the MTag and I could easily make it to work with RCDMA.
Acually I am not that much techi. But this forum gave me enough knowledge and most importantly confidence that RIMGURUS are there to extend support
I sincerely thank to Dr.Faramrozeji and aalokji
i
will this work with phones that are able to support ruim after tweak
but not data such as. photon or evo design.
This tweak is meant for most carrier locked phones ruim or non-ruim. Little different among different models.
Will not this work for EVDO on Tata DoCoMo CDMA? If yes, I'll try one.
Please let me know where from can I get Mtag (unlocked) at the cheapest rate?
sougata da, eBay.in is the best place.. some listings are of 2999, though used..
triggered from tappa-talk 2...
Edited by aalok
This method should work for most phone without LTE. Since LTE phones have most APN/PPPD disabled.
will report tomorrow, if TATA DoCoMo CDMA EVDO is working or not.. do not have TATA RUIM with me right now..
Thanks Aalok and Kapil for reply.
Will wait for Aalok's reply. Also please suggest a good Ebay deal, I'll buy one if Tata EVDO works on it.
what are the settings for tata to work with evdo, i.e. what is the apn for the same and what billing plan will be applicable ?
Confirmed to work on some rooted ROMs of Crespo4G and all ROMs of Captivate. Non-Reliance Captivate needs little more fiddling though. Captivate needs spn-conf.xml editing also.
Sent from my EVO 3D on Reliance on Tapatalk.
Can internet data made to work on pc/ laptop using bluetooth.( or by using any application)
I did not find DUN profile in MTag 3.1.
didn't try with BT but wifi tethering works great..
