rachitgpt
Help regarding opting for AirTel corporate plan
somebody is offering corporate plans to me for a one trime charge
can i take dat connection??
is deir any problems in taking a corporate plans falsely??
i dnt want to loose my no on a later stage
pls suggest
i m a airtel customer
dat guy is an acquintance of my friend
the plan offered is 275 rental with 2000 calls free
plz cmmnt
one time charge is 2000
How they give corporate plans:
Corporate plans are generally given on the following basis
1. Company named and company billed -- Connection on company's name and bill paid by company
2. Company Named self billed ----- Connection on company's name and bill paid by individual
3. Self named self billed ----- Connection on individual's name and bill paid by individual but number remains in company's CUG
Suppose if some company is taking 20connections from airtel in CUG, then the guy concerned will activate the 21st connection under the same CUG but it will be billed to you. Should not be a problem for you. And 2000 Rs is too much for it.
In bhubaneswar when I asked to get my number converted to Corporate plan, I was just asked by the ARC guy to give him the airtel number of any other employee whose plan I wanted to copy.
Cleared all my dues and the very next day I was on a corporate plan, even without being a part of that company.. :)
Try bargaining. you will get a good deal. And 275 for 2000 is really good.
me too looking for some corporate connection of Airtel in delhi
I would not go for Airtel even if they give free.
^^^ will they give it for free ????
They are nowhere close to be called as cheap or less expensive even :P
he is also offering unliited bis for 2000 rs for lifetime but the concern again is that i want to convert my existing no.......................if on a later stage i want to convert on to a normal plan den i should not loose my no.
pls suggest
pls suggest
no you wont lose your number. You will always have the option to take a retail plan if u need in future.
If he's offering unlimited BIS for life included in the plan , I'd be keen to know more mate.
he is charging extra for dat
but yess he is giving bis free 2g
