Maverick75 14 Report post Posted October 25, 2012 In stock rom, I have to set up the APN first in order to enable the 1x/3g data. To set it up I need to go to settings-wireless and network - mobile networks - cdma data settings In this menu I can setup the apn that I use. The settings that work for this network are as follows Name Reliance Net Connect PPP Digit: #777 Username : my 10 digit mobile number Password : my mobile number again Security : chap Data bearer : none After doing this setting my phone connects to 1x/3g data networks Custom Gingerbread Rom (TouchWiz and Mtd) Scene 1: As per all the guides that accompany the roms regarding correct flashing, all say that we need to wipe data, dalvik and cache. If I follow this and wipe all three (specially data), I have a properly working phone except for the data. I lose connection to the 1x/3g data networks. Everything else works fine. I have already tried copy pasting the files in the system /etc/ ppp folder. Also tried replacing the apns config file with the file from stock rom with no positive results. Scene 2 If I flash the geewiz 2.8 , geewiz 2.9 or tsm 2.2 resurrection rom directly over my stock rom, without wiping the Data, dalvik and cache, I get a perfectly working phone with 1x/3g data working. This works only for TouchWiz froyo and GB roms as the data files are different in mtd roms. Scene 3 If I flash the geewiz 3.2 Jelly bean rom without wiping data, dalvik and cache, the phone stays at the X logo permanently. If I wipe all three, the phone works properly but again I lose my 1x/3g connection. From all the above scenarios, it is confirmed that the data connectivity is dependant on the data files as whenever they are wiped or converted to mtd, I lose data connection. Is there any solution for this problem you can think of? 1 Share this post Link to post Share on other sites
rajanmehta 4,056 Report post Posted October 27, 2012 Have you tried getting an MEID based username/password data dump file from a reputed seller instead of configuring APN/MDN based data settings? Once it's registered in Reliance System THEN you can flash it through CDMA Workshop in NV items even if APN based Data parameters get wiped out every time you flash a Custom ROM. Share this post Link to post Share on other sites
aalok 442 Report post Posted October 27, 2012 if i remember correctly, OP has official i500 by reliance.. triggered from tappa-talk 2... Share this post Link to post Share on other sites
