dev997
Worldphone GSM capability on Motorola Razr M / Razr HD
Hi All,
I'm thinking of buying Motorola Razr M by Verizon.I'm particularly smitten by the compact size of the phone for a 4.3 incher as well as good specs.
As most of u might know , it also has a Worldphone capability with GSM slot like Photon etc, I was wondering if it has same issues like USSD code etc that were present in photon.
if anyone have imported it and used it, can u please give me an insight if its worth getting this phone. I occasionally use RCDMA and mainly looking for using it for GSM. So need to know it works without issues or not with GSM.
GSM not working ON Droid Razr HD
Tested
  • Like 5
Tested
Thanks.. what about Razr M ... I know for a fact that it has Worldphone capability as triband 3g GSM radio. So it should work out of the box.
Verizon Has Locked the Area Code Where they can Provide CDMA Service
When u Insert GSM Sim it will Give Restricted Area Message, So GSM can be Used in Europe Where there is No CDMA it Seems.
Verizon is Just Bull****
But this Device is Real killer... Damn Good For CDMA Users....
