akash 0 Report post Posted April 11, 2005 I set the ring type to 'vibrate + ring' yesterday. Now, for every incoming call it only vibrates and doesn't ring after sometime. When I tried to reset the ring type to 'ringing' it says OK but doesn't actually set it to ringing. This is very annoying as most of the incoming calls are getting missed due to no ring. Anyone else has faced this problem before and was able to solve it? Is it possible to reset the mobile somehow and bring it back to 'ringing' mode? Any help appreciated. Share this post Link to post Share on other sites
Vishal Gupta 4 Report post Posted April 11, 2005 Try to change the ringtone that u set as default ringtone. May be the ringtone not working properly? Share this post Link to post Share on other sites
Chirag 5 Report post Posted April 11, 2005 Check up the volume of ringtone as well. Moreover which version of the s/w is loaded on ur phone? Share this post Link to post Share on other sites
akash 0 Report post Posted April 12, 2005 The S/W version is R32 REL11 and PRL is 1. Even setting the default ringtone and setting the volume to full doesn't work. However, I am able to listen to ringtones in R-World !! Any ideas... Check up the volume of ringtone as well. Moreover which version of the s/w is loaded on ur phone? 29736[/snapback] Share this post Link to post Share on other sites
rakesh5295 0 Report post Posted April 12, 2005 Go to lg service center and they will fix it. Share this post Link to post Share on other sites
Chirag 5 Report post Posted April 13, 2005 Jus get a s/w upgrade and ur prob will be mostly solved. If it doesn't even after an upgrade tell the Service Center dude n he'll help u wid it. Share this post Link to post Share on other sites
