dr.faramroze
[Android] CDMA Tools
Here are some small tools to help configure CDMA Android phones. As an example, epst on 4.0.3/Sense 4.1 ROM on EVO3D does not work. Some epst does not work on some ROMS. I am using Viper ROM Sense 4.1 on EVO3D and stock epst did not work. I pushed in epst(2) of EVO LTE and now it works. Root Explorer>system>app and tick all permissions. Rename to epst.apk. Reboot!
If you are using sim based Android phones like Galaxy Y or Galaxy duos cdma and would like to know your MIN/IMSI/MSID then install vz.phonenumber.apk. No need to read in cdma ws via dumb phone.
com.htc.android.epst-233.apk
EPST (1).apk
EPST (2).apk
EPST.apk
net.sytes.vz.phonenumber-1.apk
  • Like 5
Can these apk used in CM based roms?
See, HTC ROM developers use extension of base of some other HTC phone that can be GSM like One S ported on EVO3D. So epst does not work in a ported base rom. CM 7/9/10 supports various epst. Can try any of these. Will upload few more different ones to support majority of roms.
EVOing using Tapatalk on Reliance
gr8! but i think it wont work on imported ones!
